Nitromethane Q&A..
Old Jan 18, 2007 | 02:04 PM
Ultimate CC's Avatar
Nitromethane Q&A..
I just wanted to start a thread on this, been using it for about 2 months now and its really amazing what so little can do on a tune...
Old Jan 18, 2007 | 02:28 PM
SlowCar's Avatar
88ml
100% nitromethane is $29.40/kg ~88ml
how much do you put in methanol?
Old Jan 18, 2007 | 02:30 PM
ibanez_926's Avatar
top fuel evo's
Old Jan 18, 2007 | 02:43 PM
I have been experimenting with many different mixtures, have gotten mixed results, I would rather not say on the forum what % as I don't want people just trying it as it can be dangerous stuff...if you look on the aquamist forums Richard has some nice threads about it and what % stays in solution and what not...
Old Jan 18, 2007 | 03:05 PM
SlowCar's Avatar
gezzz....you started the thread and now you say "I would rather not say on the forum what % as I don't want people just trying it as it can be dangerous stuff"
how much...or the range of concentrations used for your experiments? what sort of mixed results did u observed?
Old Jan 18, 2007 | 03:35 PM
I just don't want joe smo coming hear reading and just trying it, I have been playin with different %, I use 50% methanol, and I vary the water from 40-46% and the nitromethane from 4-10% give or take...
Old Jan 18, 2007 | 03:38 PM
SlowCar's Avatar
why not 90% MeOH + 10%CH3NO2? Is H2O necessary?
they are all volumetric percentages right?
Old Jan 18, 2007 | 03:41 PM
EVOLVEU's Avatar
I was looking at some Nitromethane recently. I was unsure on how much to use, so I didnt use any. I am still interested in this stuff though. I believe one of the evo gurus has some experiance using this stuff, hopefully he will chime in with some information.
Old Jan 18, 2007 | 03:42 PM
I don't like running straight meth, im a fan of having water...
Old Jan 18, 2007 | 03:46 PM
SlowCar's Avatar
how much change in AFR did you notice going from 4 to 10% nitro?
Also you mentioned mixed results, how so?
Old Jan 18, 2007 | 03:52 PM
see the crazy part is you don't see much change in afrs but it does make the car run leaner, so I would tune the car first to be a little rich and then dumb it in and go from there, mixed results were from the higher than 10% because I was running lean and it wasn't staying in solution, right now I am trying to figure out whats the lowest % I can run without sacrificing power...
Old Jan 18, 2007 | 03:55 PM
SlowCar's Avatar
maybe upping methanol will help nitro stay in solution?
You running lean because you got high egt...but not able to see it on the wb?
Old Jan 18, 2007 | 04:00 PM
yea the egts start to climb higher than norm, btw I am by no means an expert on this stuff, I made this thread to hopefully learn more about it and help other learn, all I know is what I have seen so far and I am hooked...my tranny died on me in the middle of doing pulls...I was spinning 1-3 with snow tires without nitrous which usually is only possible on nitrous for me...it was pretty wild...
Old Jan 18, 2007 | 04:02 PM
SlowCar's Avatar
i'm trying to learn as much from you as possible b/c jestr is tuning my car sta jan20 and if this nitro stuff is that good, i'll overnight a kilo of it to try it.
Old Jan 18, 2007 | 04:25 PM
Well snow performance sells nitrobooster but they don't explain the % that is in it, that you mix 8oz to 2qt and has been shown time and time again to make almost 30whp with no tuning...I can get you a hookup on some of that if you would like but its about 40 dollars a bottle, very very expensive...
