Tephra!
Old Aug 20, 2008 | 07:02 PM
Tuner@Swift's Avatar
Tephra!
Dude, clean your inbox!
Here is a copy of the speed density patched ECU (change extension to .rar and use winrar). If you could take a look at it and see if you can implement Knock CEL, NLTS and alt maps that would be freaking awesome. Here is the .xml I use for it as well:
<rom>
<romid>
<xmlid>88590015</xmlid>
<internalidaddress>f52</internalidaddress>
<internalidhex>88590015</internalidhex>
<make>Mitsubishi</make>
<market>USDM</market>
<model>Lancer</model>
<submodel>EVO9</submodel>
<transmission>Manual</transmission>
<year>2006</year>
<flashmethod>mitsukernelocp</flashmethod>
<memmodel>SH7055</memmodel>
</romid>
<include>evo9base</include>
<scaling name="1bytefactor" units="units" toexpr="x/((32/10)*100)" frexpr="x*((32/10)*100)" format="%.1f" min="1" max="2" inc="0.1" storagetype="uint16" endian="big"/>
<scaling name="ECUTime" units="ms" toexpr="1000*x/102" frexpr="102*x/1000" format="%.0f" min="0" max="100000" inc="1" storagetype="uint16" endian="big"/>
<scaling name="Load Percent" units="Percent" toexpr="x/960*100" frexpr="x*960/100" format="%.0f" min="0" max="100" inc="1" storagetype="uint16" endian="big"/>
<scaling name="PercentAFR" units="Percent Fuel" toexpr="x/255*100" frexpr="x*255/100" format="%.1f" min="0" max="100" inc="0.4" storagetype="uint8" endian="big"/>
<scaling name="RPMSpool" units="RPM" toexpr="x*31.25" frexpr="x/31.25" format="%.0f" min="0" max="9000" inc="1" storagetype="uint8" endian="little"/>
<scaling name="ThrottlePercentage" units="%" toexpr="x/255*100" frexpr="x*255/100" format="%.0f" min="0" max="100" inc="1" storagetype="uint16" endian="big"/>
<scaling name="Volts8" units="Volts" toexpr="x*5/255" frexpr="x/5*255" format="%.2f" min="0" max="5" inc="0.05" storagetype="uint8" endian="big"/>
<scaling name="percent16" units="Percent" toexpr="x/65535*100" frexpr="x/100*65535" format="%.2f" min="0" max="100" inc="0.05" storagetype="uint16" endian="big"/>
<table name="Asynch_Acell_Enrichment" category="Fuel" address="1254" type="2D" level="1" scaling="uint16">
<table name="X" type="Static Y Axis" elements="5">
<data>pause_period</data>
<data>min_TPSdelta</data>
<data>Max_pulsewidth</data>
<data>idle_TPSRange</data>
<data>after_engine_start_addition</data>
</table>
</table>
<table name="Asynch_VS_TPSDELTA" category="Fuel" address="32b6" type="2D" level="1" scaling="uint8">
<table name="X" type="Static Y Axis" elements="9">
<data>0</data>
<data>1</data>
<data>2</data>
<data>3</data>
<data>4</data>
<data>5</data>
<data>6</data>
<data>7</data>
<data>8</data>
</table>
</table>
<table name="Asynch_TPS(Rpm) Limit" category="Fuel" address="32c6" type="2D" level="1" scaling="WGDuty">
<table name="X" address="6c26" type="Y Axis" elements="10" scaling="RPM"/>
</table>
<table name="Asynch_Accel_vsRPM" category="Fuel" address="32e4" type="2D" level="1" scaling="uint8">
</table>
<table name="MAPtoMAF VE" category="Misc" address="2d7c" type="2D" level="1" scaling="percent16">
<table name="RPM" address="6bfa" type="X Axis" elements="17" scaling="RPM"/>
</table>
<table name="MAPCalibration" category="Misc" address="48056" type="2D" level="1" scaling="Volts8">
<table name="MAP_Voltage" address="4800a" type="X Axis" elements="17" scaling="Volts16"/>
</table>
<table name="MAP temper Compensat" category="Misc" address="2d94" type="2D" level="1" scaling="percent16">
<table name="Airtemp" address="714a" type="X Axis" elements="8" scaling="Temp"/>
</table>
<table name="MAP_to_MAF_OFFSET" address="13c06" type="1D" level="1" scaling="int16"/>
<table name="MUT table" category="Misc" address="3ee84" type="3D" level="1" scaling="Hex16">
<table name="X" type="Static X Axis" elements="32" scaling="Hex16">
<data>-</data>
<data>0</data>
<data>-</data>
<data>1</data>
<data>-</data>
<data>2</data>
<data>-</data>
<data>3</data>
<data>-</data>
<data>4</data>
<data>-</data>
<data>5</data>
<data>-</data>
<data>6</data>
<data>-</data>
<data>7</data>
<data>-</data>
<data>8</data>
<data>-</data>
<data>9</data>
<data>-</data>
<data>A</data>
<data>-</data>
<data>B</data>
<data>-</data>
<data>C</data>
<data>-</data>
<data>D</data>
<data>-</data>
<data>E</data>
<data>-</data>
<data>F</data>
</table>
<table name="Y" type="Static Y Axis" elements="30">
<data>MUT0X</data>
<data>MUT1X</data>
<data>MUT2X</data>
<data>MUT3X</data>
<data>MUT4X</data>
<data>MUT5X</data>
<data>MUT6X</data>
<data>MUT7X</data>
<data>MUT8X</data>
<data>MUT9X</data>
<data>MUTAX</data>
<data>MUTBX</data>
<data>MUTCX</data>
<data>MUTDX</data>
<data>MUTEX</data>
<data>MUTFX</data>
<data>MUT10X</data>
<data>MUT11X</data>
<data>MUT12X</data>
<data>MUT13X</data>
<data>MUT14X</data>
<data>MUT15X</data>
<data>MUT16X</data>
<data>MUT17X</data>
<data>MUT18X</data>
<data>MUT19X</data>
<data>MUT1AX</data>
<data>MUT1BX</data>
<data>MUT1CX</data>
<data>MUT1DX</data>
</table>
</table>
<table name="MAP Scaling" category="MAPSensor" address="670c" type="2D" level="1" scaling="uint8">
<table name="MAP Output" address="800e" type="Y Axis" elements="9" scaling="Volts16"/>
</table>
<table name="MAP Fault Trig: Mid VE Max #1" category="MAPSensor" address="29d6" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Fault Trig: Mid VE Min #1" category="MAPSensor" address="29b6" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Fault Trig High VE #1" category="MAPSensor" address="29bc" type="1D" level="1" scaling="Volts16"/>
<table name="MAP vs Baro" category="MAPSensor" address="283c" type="1D" level="1" scaling="uint16"/>
<table name="EGR MAP Offset #1" category="MAPSensor" address="4936" type="2D" level="1" scaling="uint8">
<table name="RPM" address="74de" type="Y Axis" elements="9" scaling="RPM"/>
</table>
<table name="EGR MAP offset #2" category="MAPSensor" address="4946" type="2D" level="1" scaling="uint8">
</table>
<table name="EGR Pressure Diff" category="MAPSensor" address="1b7c" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Comparison" category="MAPSensor" address="2838" type="1D" level="1" scaling="Volts16"/>
<table name="Tephra Mod Options" category="Mods" address="4818c" type="3D" scaling="uint16">
<table name="X" type="Static X Axis" elements="1">
<data>Value</data>
</table>
<table name="Y" type="Static Y Axis" elements="8">
<data>Flash ICS when on Alternate Map?</data>
<data>Enable Alternate Maps Master? ADC0F=1</data>
<data>Enable Valet Mode?</data>
<data>Flash CEL on Knock?</data>
<data>Enable No Lift to Shift?</data>
<data>Enable Auto-Valet on Fresh Ignition?</data>
<data>Enable RearO2 Simulator?</data>
<data>Enable MAP Averaging?</data>
</table>
</table>
<table name="KnockSum Required for Slow CEL" category="Mods" address="4819c" type="1D" scaling="uint16"/>
<table name="KnockSum Required for Fast CEL" category="Mods" address="4819e" type="1D" scaling="uint16"/>
<table name="Load Required for CEL on Knock" category="Mods" address="481a0" type="1D" scaling="Load"/>
<table name="CEL on Knock flash time" category="Mods" address="481a2" type="1D" scaling="ECUTime"/>
<table name="Valet Rev Limit" category="Mods" address="481a4" type="1D" scaling="RPMLimit"/>
<table name="Valet Rev Limit Time to Activate" category="Mods" address="481a6" type="1D" scaling="ECUTime"/>
<table name="Valet Rev Limit Flash Time" category="Mods" address="481a8" type="1D" scaling="ECUTime"/>
<table name="NLTS RPM Drop" category="Mods" address="481aa" type="1D" scaling="uint16"/>
<table name="NLTS TPS Threshold" category="Mods" address="481ac" type="1D" scaling="ThrottlePercentage"/>
<table name="NLTS Speed Threshold" category="Mods" address="481ae" type="1D" scaling="VehicleSpeed"/>
<table name="NLTS Load Threshold" category="Mods" address="481b0" type="1D" scaling="Load"/>
<table name="Alternate Map Time to Activate" category="Mods" address="481b2" type="1D" scaling="ECUTime"/>
<table name="Alternate Map Load Threshold" category="Mods" address="481b4" type="1D" scaling="Load"/>
<table name="Alternate Map ADC0F Threshold" category="Mods" address="481b6" type="1D" scaling="Volts16"/>
<table name="2byte to 1Byte Load Factor" category="Mods" address="481b8" type="1D" scaling="1bytefactor"/>
<table name="Alternate Injector Scaling" category="Mods" address="49b40" type="1D" scaling="InjectorScaling"/>
<table name="Alternate Hi Octane Fuel Map" category="Mods" address="49b4d" type="3D" swapxy="true" scaling="AFR">
<table name="Engine Load" address="6ec8" type="X Axis" elements="20" scaling="Load"/>
<table name="RPM" address="6ea0" type="Y Axis" elements="15" scaling="RPM"/>
</table>
<table name="Alternate Lo Octane Fuel Map" category="Mods" address="49c8d" type="3D" swapxy="true" scaling="AFR">
</table>
<table name="Alternate Hi Octane Ignition Map #123" category="Mods" address="49dcd" type="3D" swapxy="true" scaling="Timing">
<table name="Engine Load" address="6f2c" type="X Axis" elements="21" scaling="Load"/>
<table name="RPM" address="6efa" type="Y Axis" elements="20" scaling="RPM"/>
</table>
<table name="Alternate Lo Octane Ignition Map #123" category="Mods" address="49f8d" type="3D" swapxy="true" scaling="Timing">
</table>
<table name="Alternate Base Wastegate Duty" category="Mods" address="4a138" type="2D" scaling="WGDuty">
<table name="RPM" address="722e" type="Y Axis" elements="16" scaling="RPM"/>
</table>
<table name="Alternate Boost Desired Engine Load" category="Mods" address="4a158" type="2D" scaling="Load8">
</table>
<table name="High Octane Fuel Map" address="2dbd">
<table name="Engine Load" address="6ec8" elements="20"/>
<table name="RPM" address="6ea0" elements="15"/>
</table>
<table name="Low Octane Fuel Map" address="2ef5">
<table name="Engine Load" address="6ec8" elements="20" scaling="Load"/>
</table>
<table name="High Octane Ignition Map 1" address="33e9">
<table name="Engine Load" address="6f2c" elements="21"/>
<table name="RPM" address="6efa" elements="20"/>
</table>
<table name="Low Octane Ignition Map 1" address="3599">
</table>
<table name="High Octane Ignition Map 2 Not used with tephra mods" address="5523">
</table>
<table name="Low Octane Ignition Map 2 Not used with tephra mods" address="56d3">
</table>
<table name="High Octane Ignition Map 3 Not used with tephra mods" address="5a33">
</table>
<table name="Low Octane Ignition Map 3 Not used with tephra mods" address="5be3">
</table>
<table name="VVT Map 1 (Main)" address="68bd" scaling="ValveTiming">
<table name="Engine Load" address="7a64" elements="20" scaling="Load"/>
<table name="RPM" address="7a96" elements="16"/>
</table>
<table name="VVT Map 2 (Not Used) Future Use" address="536b">
</table>
<table name="Injector Battery Voltage Latency Compensation" address="31d4">
<table name="Battery Voltage" address="6df4" elements="7"/>
</table>
<table name="Accel Enrichment" address="3278">
<table name="RPM" address="6c26" elements="15"/>
</table>
<table name="Rev Limit" address="118c" scaling="RPMLimit"/>
<table name="Stationary Rev Limit" address="2798" scaling="RPMStatLimit"/>
<table name="Boost Delay Timer" address="119a" scaling="Time"/>
<table name="Injector size scaling" address="1106" scaling="InjectorScaling"/>
<table name="Boost Control Load Offset" address="1670"/>
<table name="Boost Enhancement (Anti-Lag) Start RPM" address="1280"/>
<table name="Turbo Boost Error Correction" address="3f20">
<table name="Boost Error" address="7258" elements="17"/>
</table>
<table name="Boost Desired Engine Load # 1" address="3f80">
<table name="RPM" address="722e" elements="16"/>
</table>
<table name="Boost Desired Engine Load # 2 Not used with tephra mods" address="3f96">
<table name="RPM" address="722e" elements="16" scaling="RPM"/>
</table>
<table name="Boost Desired Engine Load # 3 Not used with tephra mods" address="3fb2">
</table>
<table name="Max Wastegate Duty # 1" address="3f38">
</table>
<table name="Max Wastegate Duty # 2" address="3f4e">
</table>
<table name="Max Wastegate Duty # 3" address="3f6a">
</table>
<table name="Wastegate Solenoid Activation RPM-Active" address="1668"/>
<table name="Wastegate Solenoid Activation RPM-De-activate" address="166a"/>
<table name="Wastegate Solenoid De-activation RPM-De-activate" address="166c"/>
<table name="Wastegate Solenoid De-activation RPM-Re-activate" address="166e"/>
<table name="Open Loop Load # 1" address="3060">
<table name="RPM" address="6b98" elements="16"/>
</table>
<table name="Open Loop Load # 2" address="3076">
</table>
<table name="Open Loop Throttle Low Load" address="3092">
</table>
<table name="Open Loop Throttle High Load" address="30a8">
</table>
<table name="IC Relay Timer ON Mode Switch Time" address="20a4"/>
<table name="IC Relay Timer Control RPM" address="20a6" scaling="RPMStatLimit"/>
<table name="IC Relay Timer Control Water Temp Hi" address="20a8"/>
<table name="IC Relay Timer Control Water Temp Lo" address="20aa"/>
<table name="IC Relay Control Vehicle Speed" address="20ac"/>
<table name="IC Relay Control EV" address="20ae"/>
<table name="IC Relay Timer On Time" address="20b0"/>
<table name="IC Relay Timer Off Time" address="20b2"/>
<table name="IC Relay Timer Control Judgement Hi" address="20be"/>
<table name="IC Relay Timer Control Judgement Lo" address="20c0"/>
<table name="IC Relay Timer Air Temp" address="20c2"/>
<table name="Desired ISCV intial step position with AC off-Neutral" address="3d24">
<table name="Engine Temp" address="70c2" elements="8"/>
</table>
<table name="Desired ISCV intial step position with AC off-Drive" address="3d38">
</table>
<table name="Desired ISCV intial step position with AC on-Neutral" address="3d4c">
</table>
<table name="Desired Idle RPM-Neutral" address="3d60">
</table>
<table name="Desired Idle RPM-Drive" address="3d6e">
</table>
<table name="Boost Limit" address="3050">
<table name="RPM" address="76b0" elements="9"/>
</table>
<table name="Idle Stepper Lookup Table" address="3e31">
<table name="Throttle Postion" address="7164" scaling="uint16"/>
<table name="RPM" address="717e" scaling="RPM"/>
</table>
<table name="MAF Scaling" address="2d06">
<table name="Load" address="6da4"/>
</table>
<table name="MAF Smoothing Table" address="2d22">
</table>
<table name="Air Temperature Compensation" address="2d3e">
<table name="Degrees" address="7070"/>
</table>
<table name="Barometric Pressure Compensation" address="2d51">
<table name="Atmosphere Pressure" address="6d92"/>
<table name="RPM" address="6dd8"/>
</table>
<table name="Knock Sensor Filter Map 1" address="4361">
<table name="TAR" address="7356"/>
<table name="RPM" address="7316"/>
</table>
<table name="Knock Sensor Filter Map 2" address="441d">
</table>
<table name="Knock Sensor Filter Map 3" address="44d9">
</table>
<table name="Knock Sensor Filter Map 4" address="4595">
</table>
<table name="Knock Sensor Filter Map 5" address="4651">
</table>
<table name="Knock Sensor Filter Map 6" address="42a5">
</table>
<table name="Knock Sensor Filter Map 7" address="495b">
</table>
<table name="Knock Sensor Filter Map 8" address="4a17">
<table name="TAR" address="7356" elements="16"/>
</table>
<table name="Knock Sensor Filter Map 9" address="4ad3">
</table>
<table name="Knock Sensor Filter Map 10" address="4b8f">
</table>
<table name="Knock Sensor Filter Map 11" address="4c4b">
</table>
<table name="Knock Sensor Filter Map 12" address="4d07">
</table>
<table name="MAF Sensor Filtering" address="1108">
<table name="Load"/>
</table>
<table name="MAF Size" address="110c"/>
<table name="Min Temp for Full Boost Control" address="1e26"/>
<table name="Boost Control Limiting Vehicle Speed" address="1e2a">
<table name="Condition"/>
</table>
<table name="Boost Enhancement (Anti-lag) Stop RPM" address="1282"/>
<table name="Speed Limit" address="118e">
</table>
</rom>
File Type: zip
File Type: zip
Old Aug 20, 2008 | 07:29 PM
tephra's Avatar
lol...
How is speed density coming along?
Old Aug 21, 2008 | 05:37 AM
Originally Posted by tephra
lol...
I just got my car running again, so I'm still breaking it in. Unfortunately, Bez is off working in the jungle for weeks at a time and doesn't have time to develop it further. The version I have works, but he was going to implement a few more things to make tuning it easier.
Old Aug 21, 2008 | 05:42 AM
MR Turco's Avatar
this is awesome! Cant wait to see the final product.
Old Aug 21, 2008 | 11:08 AM
fostytou's Avatar
EvoM Community Team
oh snap! and dude, he's got it in his sig... I don't think his inbox is getting any emptier
Old Aug 21, 2008 | 11:13 AM
XBS's Avatar
XBS
So we are going to see EVO's running of MAP and a Flash in the near future ?
Old Aug 21, 2008 | 11:57 AM
Charlie_B's Avatar
we hope so. Who needs an EMS, anyways?
subscribed.
Old Aug 21, 2008 | 01:48 PM
NineWorks's Avatar
Cool stuff !
Can't wait for a release version !
Keep up the good job mates
Old Aug 21, 2008 | 05:28 PM
mrfred's Avatar
I wanted to look at what Bez had done, so I DLed and tried to open the .zip files, but no computer will decompress the files. They apprear to be corrupt or incomplete in some way.
Old Aug 21, 2008 | 06:15 PM
steadly2004's Avatar
subscribed
Old Aug 21, 2008 | 06:30 PM
Change both extensions to .rar and use winrar. It is one file in 2 parts.
Old Aug 22, 2008 | 07:43 AM
Tephra, email me at m3performance@gmail.com so we can maintain a dialogue without cluttering the forums. Thanks!
Old Aug 22, 2008 | 10:06 AM
mrfred's Avatar
Thanks. Got it now.
Old Aug 22, 2008 | 10:20 AM
sabastian458's Avatar
so this is to do what?
Old Aug 22, 2008 | 01:47 PM
fostytou's Avatar
EvoM Community Team
Speed density (VE and boost pressure used to calculate airflow/fuel requirements) on the stock ECU
IE you can remove your MAF
PPM
Apr 2, 2015 09:35 AM
mrfred
Dec 14, 2014 11:34 AM
kozmic27
Nov 26, 2012 09:07 PM
NOMIEZVR4
Oct 26, 2009 10:36 PM
Tuner@Swift
Nov 22, 2007 06:00 PM
