ECUFlash / Evoscan / Mitsulogger Questions
Old Sep 24, 2008 | 09:53 AM
  #421
D-VO's Avatar
Originally Posted by Tx4Codeman
mhm. i have evoscan 2.3 on an XP laptop that does work with my car, but 2.5 on this Vista computer does not. If anyone needs me to attemp anything in particular, let me know.
Hey bro. Yeah any help would be greatly appreciated. The only thing I haven't tried is a different computer.
Old Sep 24, 2008 | 11:29 AM
  #422
partyboy1122's Avatar
On ecuflash, what's correct way to scaling the Timing map on the LOAD section.
Can you just change the numbers from 240 to 230, then proceed to increase them in 10's.
For example. 230 240 250 260 270 280 290 300.....
Any input would be appreciated.
Old Sep 24, 2008 | 02:40 PM
  #423
Evoryder's Avatar
Still wondering if mitsulogger will ever have the ZT2 reading boost past 25.5psi..
Old Sep 24, 2008 | 02:41 PM
  #424
Evoryder's Avatar
You just change the top section but have to eliminate one of your lower load cells. I think like 70/80..a section that has them sequenced real close.
Old Sep 24, 2008 | 09:21 PM
  #425
D-VO's Avatar
No response from ECU
Hey I found something interesting. If you pull the fuse for the power locks, EVOscan doesn't work......wierd right? Maybe there's a blown fuse somewhere............
Old Sep 25, 2008 | 04:08 AM
  #426
SeanV's Avatar
Problem here with Evoscan 2.5 Map tracer and Tephra's 5.10 mods.
Prior to using the 5.10 mods, the map tracer function in Evoscan 2.5 was working fine. I was logging "Load Calculated"
I have now switched over to the 5.10 mods and log "1 byte Load", but now Evoscan Map tracer does not work. I can get into the map tracer function fine, load my xml and rom, but when i clcik on ingition or knock sum, the values are dislayed in the top most table.
Any idea what is causing the problem?
Thx.
My ROM ID is 96530006
Old Sep 25, 2008 | 04:38 AM
  #427
tephra's Avatar
ok I assume evoscan is looking for whatever the old load variable was called.
So what you can do is just rename the 1byte load to whatever the other one is called... Probably both the display name and the ID...
Old Sep 25, 2008 | 04:57 AM
  #428
tephra's Avatar
Old Sep 25, 2008 | 05:19 PM
  #429
D-VO's Avatar
No Response From ECU
OK. For anyone who's interested I figured it out. Since it's been over a year since I last drove my car, I forgot that I modified the baudrate so it will read at 62500. It works fine now.
Old Sep 25, 2008 | 06:00 PM
  #430
Jack_of_Trades's Avatar
Thats what I do with the RPM and 2byteRPM. The POWER section uses the standard "RPM" logging for its formula so I just edit it to read the 2byte values for more accurate results.
Old Sep 25, 2008 | 07:31 PM
  #431
Tx4Codeman's Avatar
Mine has not been modified, as its value is still 15625.
Old Sep 26, 2008 | 08:29 AM
  #432
CGMSTI's Avatar
this might sound like a stupid question but... whats the difference between the write to ecu and test write to ecu in ecuflash?
would test write to ecu be the one i should choose while tuning the car and then write to ecu when i am done?
Old Sep 26, 2008 | 09:53 PM
  #433
What's the actual formula for lbs/min?
Mine is reading decimals
For example .350, 1.344 etc
Thanks
Old Sep 26, 2008 | 10:05 PM
  #434
Thanks
Email me your data file for your evoscan and I'll figure out whats up for you.
Old Sep 27, 2008 | 11:23 AM
  #435
Thanks James!
