Factory Boost Control VS upgraded boost assembly (pill)
Old Nov 29, 2008 | 07:45 AM
  #31
philamthebest's Avatar
When will you start playing the Pills on the cars? is this something you do now?
Old Dec 2, 2008 | 06:06 PM
  #32
xbox4414's Avatar
Bryan when are your pills gonna be available? I'm local and would like to try a few things...
Old Dec 2, 2008 | 06:26 PM
  #33
jmorris1027's Avatar
Put me down for 1...where do I sign up?
Old Dec 2, 2008 | 06:37 PM
  #34
spdracerut's Avatar
Originally Posted by Boostd4
As a testament to what this pill can do, Bryan installed the GST assembly in my car tonight. Prior to this new pill, my tune was dropping boost like crazy on the top end...it appeared to be a boost leak. In fact, it was a problematic stock boost assembly.
I wouldn't say the stock setup was 'problematic'. I'd say it performed exactly as designed. The stock pill is sized to limit boost to exactly what it does; it's a mechanical safety device to prevent overboost and therefore probably warrenty down the road.
Old Dec 2, 2008 | 09:32 PM
  #35
nj1266's Avatar
What size pill are you using? #65?
Old Dec 2, 2008 | 09:36 PM
  #36
RazorLab's Avatar
Same as the Evo 8/9.
Old Dec 3, 2008 | 12:04 PM
  #37
Boostd4's Avatar
Well, compared to the other set of cars Bryan tuned originally...there were only two of us (my GSR and one other MR) that had this issue. I believe mine was more pronounced than the other car..so in my eyes it was problematic because it was limiting boost whereas others were tuning just fine.
Old Dec 3, 2008 | 12:14 PM
  #38
MR Turco's Avatar
bryan what are you using for logging?
Edit: nevermind i just saw your response in another thread. I am looking forward to the new boost lines
Old Dec 3, 2008 | 05:55 PM
  #39
spdracerut's Avatar
My hunch is the issue was probaby with the actuator itself. Much less variation in the boost control system as opposed to the actuator itself (variability in preload set from factory, actuator spring rate, etc).
But again, the idea for the sizing of the stock pills IS to limit boost
Old Dec 3, 2008 | 07:42 PM
  #40
Boostd4's Avatar
Agreed, but it was limiting my powahhh . So for my needs it was "broken"
Old Dec 3, 2008 | 07:46 PM
  #41
spdracerut's Avatar
Hahahhaaaa
Old Dec 4, 2008 | 01:51 PM
  #42
Jason's Avatar
Will the pill upgrade generate the same results as the jun or forge actuator mods ?? Im really curious to know if they basically do the same thing, just a different way to do it ??
Old Dec 4, 2008 | 09:05 PM
  #43
spdracerut's Avatar
Sorta.....
The stock wastegate actuator is rated at ~11psi. So if there were no boost control system, you'd only get 11psi of boost.
Now the stock boost control system works like any other electronic boost controller in that the boost solenoid bleeds off air before it gets to the actuator in order to keep the actuator shut to build more boost. Basically, it modifies the 'signal' going to the actuator to fool it into staying shut. Now the stock system comes with these 'boost pills' that limit how much the 'signal' can be modified.
So the modified boost pills allow the signal to be modified more keeping the wastegate actuator shut longer. But there's still a physical limitation based on the spring in the actuator as to how much boost it can hold. So at some point, regardless of what you do to the boost control system, the actuator will still open up because the spring is too weak to keep the wastegate flapper shut.
Old Dec 5, 2008 | 04:25 AM
  #44
Jason's Avatar
Sorta.....
Ok cool, thanx for the break down {thumbup**
Old Dec 10, 2008 | 07:49 AM
  #45
pltek's Avatar
so here is a kewl explanation of stock evo9 boost control system and where the pills
http://www.accessecu.com/accessport/...ks%20v1.07.pdf
here is the X stock boost control system diagram
http://www.roadraceengineering.com/e...lsolenoids.htm
i belive in 9 pill near the selonoid was removed so it would bleed all air back into intake and pill near the actuator would be made smaller as to make it think that system was running less boost
so razorlab, question is where are the pills on the X and what to do with them?
