Factory Boost Control VS upgraded boost assembly (pill)
Old Dec 14, 2008 | 10:51 PM
  #61
DC_TypeR's Avatar
NICE Gains Bryan.
Got a question for you...
I'm already tuned on ECUtek.... You said this one is tuned on ECUFlash... Would I see the same gains if I were to do the "pill" mod?
Mike W is controlling the boost via ECUTek, no MBC/EBC other then the ECUTek.
I'm also going to be re-tuned w/ the FP Red, Forge Waste gate actuator.
Any help would be great.
Thanks,
Chris
Old Dec 14, 2008 | 11:02 PM
  #62
RazorLab's Avatar
Any tuning software that has access to the correct boost tables (EcuTek, COBB, Ecuflash) and a tuner that knows how factory ECU-controlled boost works can tune the Boost Assembly upgrade correctly.
You are in great hands with Mike@RRE.
Old Dec 14, 2008 | 11:04 PM
  #63
DC_TypeR's Avatar
Bryan,
Thank you much for the speedy reply.
PM me when the Boost Pill is ready for the X guys, I would like one.
Or if it already is, lemme know where to paypal.
Thanks,
Chris
Old Dec 15, 2008 | 06:16 AM
  #64
SupremeX's Avatar
It is available. I received mine about a week ago. It is the same pill as the IX, at least that is what I was told when I called and talked to Bryan.
Old Dec 15, 2008 | 08:21 AM
  #65
smgevo's Avatar
Interesting mod. Nice results. What are the advantages of this pill if you already have a tune and can adjust boost within the software?
Old Dec 15, 2008 | 06:07 PM
  #66
spdracerut's Avatar
The 'pill' is a flow restrictor in one of the lines going to the boost solenoid. Basically, it's a physical/mechanical limitation on the system that will only allow a certain amount of boost regardless of the duty cycle of the boost solenoid.
By changing the size of the hole in the pill/restrictor, you change the limit of the amount of boost you can run.
Old Dec 16, 2008 | 09:21 PM
  #67
davidiii's Avatar
Im slightly confused. This pill needs tuned for correct? Well, from what i've seen, you can obtain the same boost levels/rpm range from just an ecutek tune alone...Im not really sure if i see how the pill is helping when a tune can handle this as well. Please enlighten me.
Old Dec 16, 2008 | 09:37 PM
  #68
RazorLab's Avatar
No matter the software used to tune, there is always a duty cycle limit and will quickly be hitting the limit in the upper RPM ranges with the stock assembly. The upgraded assembly allows more boost for the same duty cycle.
Old Dec 16, 2008 | 09:39 PM
  #69
davidiii's Avatar
Ahhh thanks for clearing it up
Old Dec 16, 2008 | 10:30 PM
  #70
EvoSwaggA's Avatar
so pretty much any competent tuner can tune when on the "pill" correct?
if so, what does all the necessary hardware cost and where do I buy?
Old Dec 16, 2008 | 10:36 PM
  #71
xbox4414's Avatar
Serious Bryan, when can we pick these up? LOL
Old Dec 16, 2008 | 11:04 PM
  #72
GST Motorsports's Avatar
If you would like to just replace the factory pill with the upgraded pill you can get it here:
http://www.gstmotorsports.com/store/...oducts_id=1050
We should have the full "swap" boost assembly available soon.
Old Dec 17, 2008 | 06:36 AM
  #73
davidiii's Avatar
How does your boost assembly differ from stock? (Besides the pill)
Old Dec 17, 2008 | 10:10 AM
  #74
It is a 100% OEM boost assembly with the upgraded pill installed. It's useful for swapping with the current boost assembly on the car. Some people don't like molesting their stock assembly so we offer this as well.
Old Dec 17, 2008 | 10:44 AM
  #75
Rguy's Avatar
If we buy these pills do we get screenshots or maps of the boost control tables we need to change?
