Piston Comparison
Old Jan 21, 2009 | 03:59 AM
  #91
sparky's Avatar
TedB: What is the static C.R. in your long rod engine?
Old Jan 21, 2009 | 07:23 AM
  #92
Ted B's Avatar
Originally Posted by JKav
Note the single gate used on the twin scroll manifold...
A single gate works for me as well. It just has to be correctly engineered.
Originally Posted by MJ23FE
Ted, do you do consulting work for setup design?
To consider investing my time and energy that way on a professional basis, I'd need to be part of a cause (e.g. racing project).
Mine is about 8.5:1, and was originally configured around 93 octane. With E85 now readily available here, if I had to do it again, I'd peg it in the low 9s.
Old Jan 22, 2009 | 11:01 AM
  #93
JohnBradley's Avatar
Then you need to account for fuel sometimes as well. I love the tech in this thread, well done Ted
Guess my compression? Winner will receive fame and fortune...or something.
Yes these are for a 85mm 4G63. The rest of the build is currently hush hush as the customer prefers anonymity. These have lateral gas ports, accumulator grooves, contact reduction, and window milling. They still ended up a little porkier than I was hoping though.
Old Jan 22, 2009 | 11:03 AM
  #94
E7R's Avatar
E7R
11:1 ???? (!!!!!!!!!!)
Old Jan 22, 2009 | 04:49 PM
  #95
JC evo1's Avatar
whats the weight?
Old Jan 22, 2009 | 05:18 PM
  #96
jmelocik's Avatar
12.75:1 for the static compression on those high dome pistons.
Josh
Old Jan 22, 2009 | 07:02 PM
  #97
376g...more like Sumo than Ninja, but its what it takes. For the guessing game (for those playing) I'll announce the winner in 2 days
Old Jan 22, 2009 | 09:38 PM
  #98
MJ23FE's Avatar
10.5:1
-Jalal
Old Jan 22, 2009 | 11:09 PM
  #99
94AWDcoupe's Avatar
look like 12.5/1 to me
Old Jan 22, 2009 | 11:14 PM
  #100
Billy@EnglishRacing's Avatar
Can i guess? I guarantee that i am right, and would like the fame and fortune you mentioned.
Old Jan 22, 2009 | 11:37 PM
  #101
FathouseFab's Avatar
127.2:1???
Old Jan 23, 2009 | 09:11 AM
  #102
Originally Posted by Fathouse
127.2:1???
So very close
Old Jan 23, 2009 | 11:21 AM
  #103
leecavturbo's Avatar
Originally Posted by leecavturbo
can't see why higher compression would effect spool as it only happens in the "compression stroke" its exactly that and the contents of the cylinder are not released to the turbo until the exhaust stroke where compression is not happening.
yes / no ?
Old Jan 23, 2009 | 02:14 PM
  #104
MR Turco's Avatar
i want to say those pistons are 12.5 or 13:1?
Old Jan 23, 2009 | 02:30 PM
  #105
Ted B's Avatar
Smells like alcohol in here . . .
