Sponsored by:
Sponsored by: CARiD
Lift points
Old Feb 4, 2009 | 08:50 PM
WAM's Avatar
WAM
Lift points
After searching the forum, all I found was a page from an earlier Evo shop manual showing lift points front & rear center (for floorjacks) and next to each tire for the scissors jack. One thread said dealers use those scissor jack points for their hydraulic lifts.
Everyone agree with that, or are there better places to put the four lift pads on a four-arm 2-post lift?
Old Feb 4, 2009 | 09:39 PM
Dr. Ev0L's Avatar
i use the scissor jack points daily and have never had an issue. just stick with that. but watch out for the side skirts.
Old Feb 5, 2009 | 04:37 AM
sl0ev0's Avatar
watch the side skirts, aim for the pinch welds and spread the arms out enough on the lift
Old Feb 5, 2009 | 05:21 AM
boostin20's Avatar
I leave pads flat and use 2X4's I made to fit between pad and pinch seam
Old Feb 5, 2009 | 09:49 AM
WAM's Avatar
WAM
That's kinda what I had in mind, but I didn't know if people found it necessary to cut a slot in the wood to protect the underbody.
Old Feb 5, 2009 | 10:07 AM
WAM's Avatar
WAM
This is pretty cool, but kinda pricey since I'd need four of them:
http://www.eastwoodco.com/shopping/p...ProductID=2061
But I could saw off four chunks of 2-inch square steel tubing and slot one side with a plasma cutter and set those blocks between the lift and underbody. Sounds like a plan.
Old Feb 5, 2009 | 11:07 AM
stokEd's Avatar
I think the factory lifting points should be fine.
If it helps, here are the points accordingly to the X Service Manual:
Old Feb 5, 2009 | 03:51 PM
WAM's Avatar
WAM
Yeah, thanx stokEd. I hadn't seen the second page before.
I just finished using the lift to install some Rally Armor flaps. Fitting to the lift isn't quite as easy as that drawing would suggest. What you don't see on the chassis drawing is the jacking points don't stick down lower than other stuff, including fiberglass. In order to fit the X to a lift you have to extend the contact points, and sure enough your picture shows those pads screwed to a higher position. Unfortunately most lifts (my lift) don't have those screw adjustments.
So I used 2x4 blocks above the pads. 12" in front but only 6" in back because there's a little square rib back there that might be fiberglass and you need a short block to stay off it. Took the best part of an hour to figure it out the first time. It'll be easier from now on. Thanx to everyone who responded.
Old Feb 5, 2009 | 03:57 PM
CaliMR's Avatar
hockey puck with a groove cut under the pinches
Old Feb 5, 2009 | 06:07 PM
WAM's Avatar
WAM
Not thick enough. By the time you slot them you won't have a thick enough spacer. But that may just be my lift as the arms taper slightly down to the pads. They hit the skirts.
Old Feb 5, 2009 | 06:57 PM
boostin20's Avatar
There are no notches needed in the 2x4's, they work fine as is depending on which rack you use(some you might have to shave some and make the block thinner or lift on the fender to fit block under). Check out eds pic, wood goes under pinch seams.
These are the pinch seams I was referring to. The reason they are telling you to go where the notches are is to ensure you lift where the pinch seam is double thickness.
WhoppyHopper
Aug 4, 2017 11:33 AM
kpt6
For Sale - Wheels / Tires
May 12, 2017 12:29 PM
MISHI
Oct 5, 2010 10:20 PM
racer135
Apr 7, 2008 06:04 PM
shawnhayes
Aug 26, 2003 01:47 PM
