SD - first test success
Old Feb 11, 2009 | 12:09 PM
  #241
BarryC's Avatar
Originally Posted by jcsbanks
Eric, it is compensated just like stock as you describe. The air temp density table is already suitably calibrated, but could be adjusted if necessary. It is described in honki's thread.
Cossie, thanks, working on your ROM presently.
how hard will it be to log and calibrate for the gm 3 bar and MAT sensors as I have them fitted
also if possible could you please port to v 5.7 tephra mods not v 5.10 as there are issues with 5.10
cheeky I know lol
Old Feb 11, 2009 | 12:12 PM
  #242
l2r99gst's Avatar
Originally Posted by PVD04
Will this be easily ported into the Evo VIII roms? I'm currently running speed density with MaftPro on 94170015 and would love to ditch the MaftPro. I'm already set up to test with MAP sensor and MAT, so I'd be happy to test the system. Unfortunately, I have no disassembly skills, so I won't be much help in that arena.
-Paul
I don't have any disassembly skills either, but I have been able to port a few patches from mrfred to my ROM. This SD patch, at least for the USDM roms, is going to require a lot of changes (map patch, mat patch, and these SD patches).
I *might* attempt to look at the changes necesarry for either 96940011 or 96530006, but most likely will have to wait for someone else to port the patch over. I think this might finally be the reason for me to switch to the 96530006 ROM, so maybe I won't even look at 96940011.
Old Feb 11, 2009 | 02:19 PM
  #243
jcsbanks's Avatar
http://banks.myzen.co.uk/90550001-v5.10fix-mods-SD.zip
If you want to apply it to another ROM just copy all the SD tables in Ecuflash.
You need to have MAP sensor logging working on request ID 38 (on its original FFFF8823 address in your MUT table) for my patch to work, unless you want to edit (in MAP calibration header 1) the FFFF8822 to another word location where your MAP sensor variable is).
This patch has 8 bit MAP sensor scaling (1.334x) since there is no simple way to get 10 bits. 8 bits ran fine on my engine. If you have a GM 3 bar change the scaling for the top row in the MAP VE table to 1.22x and then correct the values in the top row to match what they were set to before.
These patches do require disassembly to find the locations. It took me about 90 mins to do 90550001 from having no disassembly to start with, to checking it. There are some fiddly bits to find and relocate.
Old Feb 11, 2009 | 02:21 PM
  #244
cossie1's Avatar
Nice work John, will have a play tomorrow with the 3bar and evoscan
Old Feb 11, 2009 | 02:34 PM
  #245
tephra's Avatar
cheeky I know lol
what issues?
Old Feb 11, 2009 | 02:35 PM
  #246
jcsbanks's Avatar
I just went to look at 96530006 and they have done it differently! Not much space in the main routine we have been altering. It can be done but needs more thought, and soon I am away on vacation.
Old Feb 11, 2009 | 02:36 PM
  #247
cossie1's Avatar
Originally Posted by tephra
what issues?
On the ALT map, it seem the 02 sensor stops responding.
It isn't specific to 90550001, as today someone with a IX and 88570008 rang me saying he has the same issue but on the IX it throws the P0170 code.
Old Feb 11, 2009 | 02:42 PM
  #248
tephra's Avatar
front 02?
I will take a look at the code today!
but I can assure you that the altmap code doesn't even touch the 02 sensors... so not sure whats going on there! :wtf:
  #249
BarryC's Avatar
many thanks JOHN really appreciate this
Old Feb 11, 2009 | 02:47 PM
  #250
cossie1's Avatar
front 02?
Yeh the Front 02.
I haven't personally noticed this issue, as my wideband reads the same when I switch maps, and the car runs fine.
But BarryC has noticed it, and I think GrayW has also noticed it on an EDM Evo 8 rom.
I will log my car tommorrow and see if it does stop responding on the ALT map.
  #251
BarryC's Avatar
front 02?
yeah Dave sent ya an email on it mate
when I used alt maps in 5.10 for my E85 conversion the front O2 stopped reading back it just sat there frozen at 0.01v and the car ran very badly
changed the sensor and didnt make any difference flashed the rom in again
no difference
changed to 5.7 and everything was perfect front 02 again
Old Feb 11, 2009 | 02:55 PM
  #252
TeStUdO's Avatar
I will wait until this is finalized and read the "Speed Density Conversion for Dummies" thread that it is made. Great work by everyone in this thread thus far, though.
Old Feb 11, 2009 | 03:07 PM
  #253
03whitegsr's Avatar
Omnipower 4 bar and GM IAT sensors on order and hoping somebody can get this going on 94170015?
I need to buy a "real" evo...
Old Feb 11, 2009 | 03:49 PM
  #254
tephra's Avatar
no difference
can u send me the email again?
take it offline not to clog up this thread
Old Feb 12, 2009 | 06:22 AM
  #255
wreckleford's Avatar
Can you guide me on how to get this going with an AEM 3.5bar MAP sensor and a GM IAT?
