SD - first test success
Old Feb 10, 2009 | 10:50 AM
  #181
jcsbanks's Avatar
Thanks again, the approximations may look like we're missing a lot of peaks, but the outliers are usually on transients and with just a few items recorded. I tend to place most weight on the cells that are accessed frequently.
So how about for Tephra's MAP VE calibration:
10kPa: 70% of 10=7
20kPa: 70% of 20=14
30kPa: 77% of 30=23
50kPa: 77% of 50=39
70kPa: 77% of 70=54
100kPa: 90% of 100=90
130kPa: 100% of 130=130
310kPa: 100% of 310=310
RPM VE:
About 94% at 500,1000 (this should help your lean idle depending on what you have there now)
100% from 1500 to say 5500 then taper (no log info, suggest follow mine).
It is quite surprising how flat the VE is from 30-70kPa, mine is the same.
Old Feb 10, 2009 | 11:00 AM
  #182
MR Turco's Avatar
John what mods do you have versus tephra's that yields greater VE?
Also, from those logs eric posted how did you determine RPM VE.
Be gentle i am very green with SD.
Thanks!
Old Feb 10, 2009 | 11:02 AM
  #183
l2r99gst's Avatar
Just to throw the TPS data out there. This is TPS vs RPM vs the same VE (100*load/map):
I know you don't have a VE table for TPS, but I figured looking at the data for both TPS and map would be good for comparison.
Old Feb 10, 2009 | 11:18 AM
  #184
jcsbanks's Avatar
Thanks!
Nothing much, more likely just differences in our induction systems that affect the (old) MAF sensor calibrations we're trying to emulate.
Also my load is not temp compensated but I expect Tephra's is. I used non-compensated load because MAP is also not compensated at this stage, so I was comparing like with like.
RPM VE - there is drop from about 77 at 1500 RPM to 72% at 1000 RPM at the same MAP.
Old Feb 10, 2009 | 11:19 AM
  #185
jcsbanks's Avatar
TPS correlation is good Eric, if it wasn't for the ISCV (being a second throttle) it would be worth trying instead of MAP.
Old Feb 10, 2009 | 11:34 AM
  #186
MR Turco's Avatar
Forgive me, i still don't see where you are getting the 72% at 1000rpm. I am probably looking at the wrong table.
Old Feb 10, 2009 | 12:17 PM
  #187
jcsbanks's Avatar
Post #180, 40kPa, 1000 RPM.
Old Feb 10, 2009 | 12:25 PM
  #188
MR Turco's Avatar
oh so you just take the lowest value. I was thinking you averaged out the values at 1000rpm. I will wait until the system is finalized before making most inquiries.
Old Feb 10, 2009 | 01:25 PM
  #189
jcsbanks's Avatar
1000 RPM at 40kPa (idle) needs less VE than 2000 RPM at 40kPa (cruise). Since they are both at 40kPa we adjust the RPM VE to suit.
I'm using Tephra's suggestion of 16 bits for the MAP VE and calibration table, coming along nicely, although adds a few more tables to Ecuflash for the conversion...
Old Feb 10, 2009 | 02:06 PM
  #190
03whitegsr's Avatar
Anybody ever play around with how MIVEC timing affects the engine VE?
It seems like it would be a pretty significant detail, but maybe it's not?
It's awesome how you have been able to fit SD so nicely into the factory code with just a few changes. Very creative.
Old Feb 10, 2009 | 02:35 PM
  #191
tephra's Avatar
Thanks Eric.
20kPa: 70%
30kPa: 77%
70kPa: 77%
80kPa: 80%
90kPa: 85%
100kPa: 90%
120kPa: 95%
130kPa: 100%
That is 8 bins, but we can do a 10kPa and a 310kPa by coding the above creatively.
We do have to have the top value, otherwise it will just stay at the load in the last bin and would never richen beyond it - so it 130kPa was your last bin you wouldn't go over 130 load!
Hey John,
Why did you choose those as your bins?
I understand the 130kpa last bin thing, just not the 30/70/80?
Old Feb 10, 2009 | 03:21 PM
  #192
jcsbanks's Avatar
The post you quoted was just my quick note of where I felt the "breakpoints" were. Post #181 has my suggestion.
Old Feb 10, 2009 | 03:25 PM
  #193
jcsbanks's Avatar
I've used the 10 bit MAP ADC and the load lookup to word. I've got rid of the 0x73 constant and made the code independent of JDM MAP sensor scaling now. The bottom row of the MAP VE table is now scaled like load with an adjustment to counteract the MAF size multiplication (0.596). So the load lookup is now crazy detailed and has silly limits. The MAP sensor can be calibrated by simply changing the scaling for the top row of the MAP VE table and then correcting the bins to the typical values.
I have also killed the other baro check and will see if that brings the LTFT back tomorrow.
File Type: txt
Old Feb 10, 2009 | 03:27 PM
  #194
jcsbanks's Avatar
MIVEC I think has large effects on VE, so if you change your MIVEC table you may need to adjust.
Old Feb 10, 2009 | 03:28 PM
  #195
03evokid's Avatar
looks good!
