Ecuflash update?
Old Feb 24, 2009 | 06:58 PM
Jeeperjunior's Avatar
Ecuflash update?
When I go to download the newest version do i need to unistall the old version and redownload or just download the newest version over what I have? Thanks. Couldn't find it in the search and its a pretty simple question.
Old Feb 24, 2009 | 07:29 PM
tephra's Avatar
You dont need to uninstall it.
BUT I probably would manually uninstall ecuflash AS WELL AS any tactrix drivers (seperate uninstall item)
And then install the new version!
ps - what version do you have now? If you have manually changed the XML's with your current version you might find you need to make these changes again.
Old Feb 24, 2009 | 08:06 PM
I have version 1.40 now. I haven't modified it in any way. So what do you suggest?
Old Feb 24, 2009 | 08:09 PM
tephra's Avatar
in that case you should be fine just to install the new version.
However there probably wont be many changes (except for the ones listed) most of the useful stuff is definition based anyways
good luck!
Old Feb 24, 2009 | 08:32 PM
Do i save directly over the current one? Or save it in addition to it?
Old Feb 24, 2009 | 08:37 PM
tephra's Avatar
When you install the new version it *should* backup your xml's automatically then overwrite the application.
Old Feb 24, 2009 | 09:02 PM
Thank you! I got it. I just didn't want to have two programs interferring with each other.
Old Feb 24, 2009 | 09:08 PM
tephra's Avatar
no problems
if your really worried OR if there IS a problem, just uninstall all the old stuff and reinstall
Old Feb 25, 2009 | 08:45 AM
fostytou's Avatar
EvoM Community Team
I usually just append a version # to the current 'ecuflash' (IE ecuflash_1.35') install folder before upgrading. That way the worst case is I can just open up the old install. (If I'm having trouble with defs or don't have time to fix them it is a good way to not be "stuck")
The only time I've run into problems with drivers is after a partial driver upgrade. I then had multiple drivers that I just had to remove all of and re-install the driver package.
johntrav
May 7, 2014 08:45 AM
seahawks12th
Apr 18, 2010 07:27 PM
RedLanEVO
Jan 29, 2009 08:58 AM
black E
Aug 1, 2008 09:14 PM
