Another Alignment Question!
Old Mar 24, 2009 | 06:47 PM
Meevo's Avatar
So, I got my car aligned by Tires Plus today - I asked them to spec it out to -1.8 degrees camber in the front, -1.5 in the back, 0 toe.
From what I understand this camber is wholly possible using stock parts. I am riding on GTWorx Springs and Bilstein HD's, stock top hat bump stop etc.
What they ended up doing was
-1.5 -1.7
3.6 deg caster 2.9 degrees caster
0 toe 0 toe
-1.5 -1.3
-.02 toe -.02 toe
When I asked them why they didn't bring it to what I asked them to, they said it was because the spindle openings for the lower strut holes need to be ground out to get more camber adjustability.
I thought front could reach -2 degrees without any plates or anything??
Has anyone else done this spindle opening grinding thing?
What should I do?
Old Mar 24, 2009 | 06:57 PM
rolly1818's Avatar
Registered User
maximum is -1.6 i think (?)
how does ur caster not line up i have a similar problem with my caster off...?
Old Mar 24, 2009 | 07:05 PM
Meevo's Avatar
i thought it was -2.0
probably rough roads, potholes etc
bump!
Smike's Avatar
Try a different shop.
We have 2 selections for front camber -- the -1 bolt selection and -2 bolt selection. Now, on the -1 selection with my Swifts, I was seeing a true camber of -1.6 to -1.7 in the front.
Rear has much more adjustment. They should be able to get -1.5 easily and 0 toe.
Old Mar 24, 2009 | 07:11 PM
Meevo's Avatar
It sucks that I have to pay for 2 alignments...
What's all that they were talking about spindle openings? How do we "make the selection"?
Should I just let them grind it out? From what I understand, this shouldn't be necessary.. I dont understand why any shop would have trouble with this
Old Mar 24, 2009 | 07:21 PM
Meevo's Avatar
bump for more input, maybe on why the shop is having trouble reaching the adjustment or whatever.. I can't even picture what the problem seems to be, I do not get why they can't adjust it to the specs I asked
Old Mar 24, 2009 | 07:30 PM
Smike's Avatar
Attached.
Old Mar 24, 2009 | 07:48 PM
Meevo's Avatar
lol thanks.. If I show this to them, they should be able to make sense of it and do it relatively easily right? Do you know where I can find the diagram for the rear as well?
Old Mar 24, 2009 | 07:56 PM
Smike's Avatar
Attached.
But they should have been able to pull this up with their shop computer.
Old Mar 24, 2009 | 08:10 PM
rolly1818's Avatar
Registered User
SmikeEvo, u seem like the alignment man
how do i adjust caster? also why should it even be off?
Thanks
Old Mar 24, 2009 | 08:14 PM
Smike's Avatar
Caster is not adjustable with our cars. It could be off due to bent parts or a bad alignment reading from the machine. Tends to be the latter.
Old Mar 24, 2009 | 08:16 PM
Meevo's Avatar
Great - I wonder if they used this - Looking at these diagrams, how does the spindle opening play a part? It seems like all you have to do is turn the bolt?
Old Mar 24, 2009 | 08:19 PM
rolly1818's Avatar
Registered User
so caster plates should be an easy fix for this?
sorry for the thread hijack.
when they changed my camber it was as simple as turning the camber bolts. it is really DIY but you need the machine to make sure your dialed in to your specification. or if u want max camber turn the bolts so the lobe on the bolt reflects this.
Old Mar 24, 2009 | 08:27 PM
Smike's Avatar
Camber plates turned front-back (instead of side to side R-L) -- then you can change caster specs.
Old Mar 24, 2009 | 08:29 PM
rolly1818's Avatar
Registered User
sorry to ask but where can i get a good pair to buy? i am thinking since i got your attention i should get advice from a guru
Thanks again...
