Changing mininum speed on launch control?
Old May 6, 2009 | 11:09 PM
  #31
R/TErnie's Avatar
Thanks MrFred! I tested it out leaving work today Worked even with a slight roll (set @ 6kph) and was quite nice!
Old May 7, 2009 | 04:06 AM
  #32
rolly1818's Avatar
Registered User
You entered 10 s as 10000 ms, correct?
so 10000ms is a good value?
94170015?
Awesome, I always hated how the launch control would shut off with virtually any vehicle movement.
do what i did. check ur stationary rev limit address and then use that as fostytou did:
That is the correct place in the XML, whether or not it is correct is a different story.
Regarding the offset:
For example, the stationary rev limit address for 88590015 = 2798 which is 2 higher than the first address mrfred posted (remember, we are adding in hex here).
So, subtract 2 from your address and (I think) you wind up with 2748.
For the next table there is a difference of E2 (in hex), so add E2 to your 274A and you should have 282C (again, I think). These may not be correct, but this is where MrFred was suggesting you start.
Assuming the values are the same between roms the defaults are 3km/h and 2100ms. Use those addresses and see if things seem correct
Old May 7, 2009 | 05:51 AM
  #33
burnzy's Avatar
does launch control require a clutch switch like nlts does?
Old May 7, 2009 | 06:31 AM
  #34
Appauldd's Avatar
No.
Old May 7, 2009 | 06:40 AM
  #35
mrfred's Avatar
The launch control code is very different for an Evo VI ECU.
Old May 7, 2009 | 09:11 AM
  #36
fostytou's Avatar
EvoM Community Team
Correct
Not at all... unless you like to wait forever for the launch control to activate. This was just used to confirm the address and scaling. I'll probably set it to something like 750ms, but if I have my speed up at 17km/s it might be fine at the stock 2100ms. Just need to turn that over in my head a bit (it probably won't matter either way).
Old May 7, 2009 | 11:24 AM
  #37
mrfred's Avatar
Originally Posted by fostytou
Correct
Thanks. Then it must be the correct scaling.
Old May 7, 2009 | 11:38 AM
  #38
rolly1818's Avatar
Registered User
gonna set it for 750ms and see the effects later on today... Thanks again mrfred and fostytou for the knowledge and mod
Old May 7, 2009 | 12:02 PM
  #39
fostytou's Avatar
EvoM Community Team
Sorry if that was confusing.
Since we have not confirmed your address you may want to test with 10000ms (10 seconds) and something like 3k rpm. Your rev limiter should be at the normal full rev limit until after you cross under the set speed for the time that you have set. At that point you will get a new rev limiter at whatever you have set your stationary rev limit at.
After you know it is the correct address you can set it to whatever appropriate value you like. If 2100ms is working fine for you, then feel free to leave it.
Old May 13, 2009 | 01:16 PM
  #40
fostytou's Avatar
EvoM Community Team
Started looking at this for a friend with 96530006
By offset these are the addresses:
Code:
<scaling name="VehicleSpeedFreq" units="km/h" toexpr="x*0.25" frexpr="x/0.25" format="%.1f" min="0" max="64" inc="0.2" storagetype="uint16" endian="big"/>
<table name="Max Speed for Stationary Rev Limit" address="2b48" category="Misc Limits" type="1D" scaling="VehicleSpeedFreq"/>
<table name="Stationary Rev Limit Cross Under Max Speed Enable Delay" address="2c2c" category="Misc Limits" type="1D" scaling="Time"/>
km/h looks right, default for time on that rom is 3700ms. I'll see if I can get him to adjust it and let us know if it is correct.
Old May 18, 2009 | 10:35 AM
  #41
fostytou's Avatar
EvoM Community Team
88580014 by calculations (since they were never posted):
<!-- <table name="Stationary Rev Limit" address="274a"/> -->
Code:
<table name="Max Speed for Stationary Rev Limit" address="2748" category="Misc Limits" type="1D" scaling="VehicleSpeedFreq"/>
<table name="Stationary Rev Limit Cross Under Max Speed Enable Delay" address="282C" category="Misc Limits" type="1D" scaling="Time"/>
Old May 18, 2009 | 10:44 PM
  #42
ace33joe's Avatar
Using the "address offset" method as fostytou suggested, for 94170008, Max speed value is same as other ROMs, 3.0 km/h, but it seems the timer is set to the maximum value (FF in hex16). I looked at the values around that address using hex editor, and it seems they are all FF near that address, so I guess those addresses are not used?
2c2c is the calculated address for the timer value, but from 2b7a to 32ff are all "FF"s.
But if I look at the Ralliart ECU (92460000), the values are set to:
5000 rpm (stationary rev limit)
10 km/h
575 ms
which seems pretty good for real launch control, while EVO9 value (3km/h, and 2100ms) and EVO8 MR (2005 USDM) (3km/h and 4800ms) seem to be more for protecting the tranny.
I haven't launched my car yet, so I am not sure whether my "FF or 1638375 ms = ~1638 sec = ~27 minutes" is actually in effect or not.
dfarmer0033
May 18, 2017 08:43 AM
Lanart2011
Mar 11, 2016 05:27 PM
buckmarley
Feb 9, 2016 05:03 PM
Mikeodeth
15
Apr 28, 2014 07:31 PM
Yoo Shin
Cobb AccessPORT
May 25, 2012 08:39 AM
