can i bypass the immobilizer on my '06 MR?
Old Aug 22, 2009 | 09:10 PM
kaj's Avatar
kaj
i have a plethora of other theft-deterrent devices.. and i need to bypass the immobilizer to get my turbo timer working.
can it be done? i thought there was a hex code i could put in place of my imm. code? if so, please PM me.
my other option is to buy a key, have it coded.. then wire it to the car... either way, the immob. is bypassed.. i'd rather just do it with the ecu.
i did a lengthy search... to no avail.. so many conflicting opinions.
Old Aug 22, 2009 | 09:22 PM
JordanS4's Avatar
yes, it's in the periphery bits; all you have to do is use ECUFlash and a cable to disable it.
Old Aug 22, 2009 | 09:35 PM
kaj's Avatar
kaj
I'm running 88590015 with tephra 5.1.
Which bit is it and what's the hex?
Old Aug 22, 2009 | 09:45 PM
scheides's Avatar
EvoM Moderator
Search, its out there
Old Aug 22, 2009 | 09:51 PM
kaj's Avatar
kaj
Did that. Wouldn't it have been just as easy to tell me? Lol
Guess I'll keep searching till I find it or someone is kind enough to help.
Old Aug 22, 2009 | 10:38 PM
YaroRS's Avatar
You have to edit the ECU periphery bits (FAA) and disable bit 3 (usualy it says disable immobiliser)
Old Aug 22, 2009 | 10:46 PM
kaj's Avatar
kaj
In periphery 0, right? I have it set to 56D0. From what I understand, that disables my rear O2 and immob.
Old Aug 22, 2009 | 11:40 PM
logic's Avatar
http://evoecu.logic.net/wiki/Immobilizer_Disabling
Old Aug 22, 2009 | 11:50 PM
kaj's Avatar
kaj
Sweet. I was right. You, sir, are the man. Thank you!
Bypass works perfectly.
Old Aug 23, 2009 | 10:02 PM
biggie5252's Avatar
Why do you need to bypass the immobilizer for your turbo timer?
Old Aug 23, 2009 | 11:21 PM
codgi's Avatar
Indeed.
To the OP, what timer is this? I guess maybe it depends on the timer, but with the Apexi I one I have it was fine. Some aftermarket alarms don't like seeing the engine on and I haven't gotten around that but curious about this timer....
Old Aug 24, 2009 | 10:44 PM
kaj's Avatar
kaj
Originally Posted by codgi
Indeed.
it's actually part of my alarm. my car has remote start as well as a turbo timer. but the key has to be in the ignition for the car to start/run. thus, i was unable to use either. now that i disabled it, i was able to program both options of my alarm. i shoulda' clarified. haha.
i was mostly doing this to get my turbo timer option.. but as a bonus i remembered: "duh. i can do remote start too!". in the 105* heat as well as 35* winter.. remote start is a blessing.
oh. and i get to use any key i want for backup! even a super-sexy-uber jay-dee-em key.
i have many other theft deterrent devices. the immobilizer was kinda not needed anyway.
Old Sep 11, 2009 | 07:51 AM
MR Turco's Avatar
to disable the immobilizer is it FAA bit 2 or bit 3? I always though it was bit 3, however, in the wiki it is showing up as bit 2 (the third bit but not bit 3). Maybe the wiki needs to be updated or i am wrong? the default for bit 2 (the third bit) is 0 where i would think it would be 1 for enabled.
Old Sep 11, 2009 | 08:07 AM
kaj's Avatar
kaj
I'd have to check. Can't remember off the top of my head. Hopefully I saved it. I'll try to remember to look. I'm at work, on my phone right now. Shoot me a PM, as a reminder, if ya want.
adron
Jun 16, 2020 10:34 AM
Macks
Outlander Sport
Jan 22, 2016 04:33 PM
SiC
Jan 19, 2016 08:03 AM
Dnasario
Jan 16, 2016 08:52 AM
JagMix
Sep 27, 2015 10:23 PM
