can i bypass the immobilizer on my '06 MR?
i have a plethora of other theft-deterrent devices.. and i need to bypass the immobilizer to get my turbo timer working.
can it be done? i thought there was a hex code i could put in place of my imm. code? if so, please PM me.
my other option is to buy a key, have it coded.. then wire it to the car... either way, the immob. is bypassed.. i'd rather just do it with the ecu.
i did a lengthy search... to no avail.. so many conflicting opinions.
Sweet. I was right. You, sir, are the man. Thank you!
Bypass works perfectly.
Indeed.
To the OP, what timer is this? I guess maybe it depends on the timer, but with the Apexi I one I have it was fine. Some aftermarket alarms don't like seeing the engine on and I haven't gotten around that but curious about this timer....
i was mostly doing this to get my turbo timer option.. but as a bonus i remembered: "duh. i can do remote start too!". in the 105* heat as well as 35* winter.. remote start is a blessing.
oh. and i get to use any key i want for backup! even a super-sexy-uber jay-dee-em key.
i have many other theft deterrent devices. the immobilizer was kinda not needed anyway.
to disable the immobilizer is it FAA bit 2 or bit 3? I always though it was bit 3, however, in the wiki it is showing up as bit 2 (the third bit but not bit 3). Maybe the wiki needs to be updated or i am wrong? the default for bit 2 (the third bit) is 0 where i would think it would be 1 for enabled.
I'd have to check. Can't remember off the top of my head. Hopefully I saved it. I'll try to remember to look. I'm at work, on my phone right now. Shoot me a PM, as a reminder, if ya want.
adron
Jun 16, 2020 10:34 AM
audi, bypass, code, disable, evo, faa, hex, immobiliser, immobilizer, mitsubishi, periphery, timer, turbo, viii, wrx
