TephraMod V7
I've been running with this for some time now with V5.10 and it's worked great!
There's nothing to be defined in the MUT (which you probably would have guessed).
Has that been changed for V7?
Does anyone have the heater disable for 88590015 by any chance?????
wow, you totally overlooked that section,lol. you don't just CHECK OFF that box, that is just a 'label'. All of the tables below that 'label' need to be changed. In the parenthesis it tells you the value you need to enter for load OR psi based boost control. If you want load, change all of theose tables to the LOAD settings.
- thx
Code:
<table name="Heater CEL" category="Rear O2" address="2DAFB" type="2D" level="2" scaling="blobbits"> <table name="Bit values" type="Static Y Axis" flipy="true" elements="8"> <data>N/A</data> <data>N/A</data> <data>N/A</data> <data>N/A</data> <data>Rear O2 Heater CEL Enable</data> <data>N/A</data> <data>N/A</data> <data>N/A</data> </table> </table>
Just curious, what's the ETA for the Evo9 version? Days or Weeks?
I have a dyno appointment this month but I'll reschedule if 88590715 isn't going to be out in time.
Thanks guys.
Thanks guys.
Have the throttle hang issues been solved in this release? Do we need to modify the decel fuel cut and idle stepper look up tables?
For those who do not know what I am talking about the thread is here:
https://www.evolutionm.net/forums/ec...ttle-hang.html
So just everyone understands what this is. What happens is when you take for foot off the throttle under daily driving and partial throttle conditions. RPM's hang a bit and in some cases the car dumps a little more fuel and the car will buck very lightly. This is an issue on all EVO 9's and 8's if you upgrade to 9653. Thinking it has something to do with emissions, since 9653 is a 05 ROM.
I will keep this post updated with the results, if any, are found on the issue. If you go over to that thread and zero out the ISCV tables it will greatly reduce the issue and for most it will be considered a fix.
I drove my without any fix before and I considered it normal, it was something I really didn't notice. Only every now and then...
<p>
</p><p>Jack,</p><p>Can you add this above info to the XML along with this:</p><p>https://www.evolutionm.net/forums/ec...ecu-again.html</p><p>
</p>
Might I suggest adding the rear O2 sensor heater disable to this patch as well?</p><p>
</p><p>Open up the ROM, navigate to the "Mods" section, change "Rear O2 Heater Patch" from "4A0B" to "0009"</p><p>My rear O2 has been replaced with the wideband.</p><p><strong>This might also work but I need to confirm the address!</strong>
Code:
<table name="Rear O2 Heater Patch" category="Mods" address="2c62a" type="1D" scaling="Hex16"/>
Code:
<table name="Heater CEL" category="Rear O2" address="2c61e" type="2D" level="2" scaling="blobbits"> <table name="Bit values" type="Static Y Axis" flipy="true" elements="8"> <data>N/A</data> <data>N/A</data> <data>N/A</data> <data>N/A</data> <data>Rear O2 Heater CEL Enable</data> <data>N/A</data> <data>N/A</data> <data>N/A</data> </table> </table>
Code:
<table name="Ignition Coil Charge Time" category="Timing" address="41ea" type="2D" level="2" scaling="uint8"><table name="Battery" address="6808" type="X Axis" elements="9" scaling="BatteryVoltage"/></table></p><p><table name="Ignition Coil Charge Time (Unknown 1)" category="Timing" address="41fa" type="2D" level="2" scaling="uint8"><table name="Battery" address="6808" type="X Axis" elements="9" scaling="BatteryVoltage"/></table></p><p><table name="Ignition Coil Charge Time (Unknown 2)" category="Timing" address="420a" type="2D" level="2" scaling="uint8"><table name="Battery" address="6808" type="X Axis" elements="9" scaling="BatteryVoltage"/></table>
