TephraMod V7
Old Oct 16, 2009 | 05:05 AM
  #376
lan_evo_mr9's Avatar
Is there a link or any info on the correct figures for the 6spd gearbox ratios to plug into the tables?
Old Oct 16, 2009 | 06:07 AM
  #377
Jack_of_Trades's Avatar
All Evo 8 5-Speeds RPM/MPH:
  1. 176.2
  2. 117.3
  3. 84.7
  4. 62.0
  5. 43.3
Calculated by:
Tire Diameter (OEM) = 25.3"
Gear Ratios:
  1. 2.928
  2. 1.950
  3. 1.407
  4. 1.031
  5. .720
Final Drive= 4.529
Evo 8 6-Speed RPM/MPH:
  1. 177.1
  2. 118.4
  3. 87.3
  4. 67.0
  5. 52.8
  6. 42.2
Calculated by:
Gear Ratios:
  1. 2.909
  2. 1.944
  3. 1.434
  4. 1.100
  5. .868
  6. .693
Final Drive= 4.583
Old Oct 16, 2009 | 06:12 AM
  #378
Oettinger's Avatar
Originally Posted by Jack_of_Trades
Yeah I noticed, thats why I asked
In this moment no, but is possible insert throttle kicker for ALS, but is necessary retarding to -17 or small value for create ALS. Throttle kickers open throttle-body door and insert air and retarding igntion with ecu, create positive Boost 0.3b(5psi) to 0.5b(7psi) when throttle is off and remove Lag when push throttle. Exhaust create sounds (Bang-Bang) with flames. In rallys of europe is more used for remove the lag of turbos.
See this video in 2.30min or 5:00min
http://www.youtube.com/watch?v=VYbTJOEe_NY
In Spain is rallys in USA is 1/4 mille jeje
Retarding more of -15º to down is one good new option for future tephra's ecu for create real-ALS with Hardware or with kicker part.
  #379
phenem's Avatar
  1. 176.2
  2. 117.3
  3. 84.7
  4. 62.0
  5. 43.3
  1. 177.1
  2. 118.4
  3. 87.3
  4. 67.0
  5. 52.8
  6. 42.2
You list them at RPM/MPH but isn't it RPM/KPH? So are these values correct?
Here is what I got from logging my car:
6 41.8584
5 41.8584
4 61.1504
3 85.3097
2 117.478
1 177.035
0 2899.78
Old Oct 16, 2009 | 06:17 AM
  #380
fostytou's Avatar
EvoM Community Team
Originally Posted by phenem
Fosty help me setup my EVOScan to do the map tracer and I am having the exact same issue. When you try and load the BIGMAP it throws an error.
When you do what I posted in the link it works fine for me (although it stretches way off screen).
Essentially you just make a new v7 labeled xml (in the two categories on top of the xml) in the evoscan ROMS directory with only pertinent maps (and all of the scalings). IE, just put in bigmaps and if you want boost maps, etc. The includes and the maps that gray out other maps and all of the other junk are what is causing your problem, and its not needed anyway in Evoscan.
If you didn't have map tracer working already you will also need a dead loadcalc in the logs (which just makes a copy of 1 byte load in the column evoscan references.)
Old Oct 16, 2009 | 06:18 AM
  #381
phenem's Avatar
Thanks, I will give it a try!
Old Oct 16, 2009 | 07:14 AM
  #382
6 41.8584
5 41.8584
4 61.1504
3 85.3097
2 117.478
1 177.035
0 2899.78
Crap, I forget since I edit my Scalings for MPH and fahrenheit once I get a new XML.
Here are the Scalings for MPH if anyone wants to convert their XML to MPH:
Code:
<scaling name="VehicleSpeed" units="MPH" toexpr="(x*2)*0.621371192" frexpr="(x/0.621371192)/2" format="%.0f" min="0" max="317" inc="1" storagetype="uint16" endian="big"/>
	<scaling name="VehicleSpeed8" units="MPH" toexpr="(x*2)*0.621371192" frexpr="(x/0.621371192)/2" format="%.0f" min="0" max="317" inc="1" storagetype="uint8" endian="big"/>
The values I listed are calculated values, not measured with Evoscan.
Old Oct 16, 2009 | 07:52 AM
  #383
SeanV's Avatar
Thx
Works perfectly now.
Old Oct 16, 2009 | 08:16 AM
  #384
YaroRS's Avatar
MAT via fuel temperature input is already built in you would have to change it to IAT sensor if you have one or would want to use that as input.
I am trying to log this in evoscan using this command line "
<DataListItem DataLog="Y" Color="" Display="Manifold Air Temp" LogReference="MAT" RequestID="09" Eval="1.8*x-40" Unit="deg F" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-40" GaugeMax="300" ChartMin="-40" ChartMax="300" ScalingFactor="1" Notes=""/>
" wich doesnt work and for some reason it logs as Air temperature using request 3A. Any reason why it logs like this ? (I am using fuel temperature input)
Old Oct 16, 2009 | 02:30 PM
  #385
vicbdn's Avatar
Hi, I was looking through Phenem's USDM 8 ROM and it seems lean spool is disabled though start/stop RPM at 1500?
As I understand it, isn't the best way to disable lean spool through FBA Bit 0? The 1500/1500 method causes tip on knock or something?
Thanks.
Old Oct 16, 2009 | 03:21 PM
  #386
phenem's Avatar
Thanks.
I never have had a problem doing that. I can update the ROM if that's really how you turn it off, FBA BIT 0?
Can someone else confirm this?
Old Oct 16, 2009 | 04:01 PM
  #387
Yeah, FBA bit.0
Old Oct 16, 2009 | 04:02 PM
  #388
gear head's Avatar
^ correct
Old Oct 16, 2009 | 04:51 PM
  #389
phenem's Avatar
JoT can you send me the XML that you made for the psi boost control so I can update the files?
Old Oct 16, 2009 | 04:56 PM
  #390
Yeah, I'm finishing up my XML as we speak, once I'm done I'll email you a copy.
