EvoScan v2.6 And New EvoScan GPS/Logger/Reflashing Touchscreen Review
Old Apr 14, 2010 | 07:19 AM
  #1306
mfr122887's Avatar
I need it on in one version and off in one. I have one instance for logging and the other for displaying gauges. It needs to be setup this way in the front end software I am using for the carputer.
Old Apr 14, 2010 | 07:41 AM
  #1307
_Speedy_'s Avatar
hmm what about the EvoScan gauge setting called "double clickable" to start "datalog to file".. is that suitable?
Old Apr 14, 2010 | 07:46 AM
  #1308
mfr122887's Avatar
You are getting better but my gauges have alot of items being displayed while when logging I only need a few items. I thought about doing it like that but it still isn't ideal. I think i am going to launch the programs with a batch file that will also change to reg key to the proper value. I have thought about this alot and it seems as it is the only way.
Old Apr 14, 2010 | 03:55 PM
  #1309
fryedchikin's Avatar
I have not tried this, but in theory it should work
Create a new Windows user account.
Log into windows using the new account, install Evoscan and set the options as you need.
Log back into windows using your "main" account and use the "Run as a different user" option to launch your second copy of Evoscan.
Old Apr 15, 2010 | 03:07 AM
  #1310
_Speedy_'s Avatar
nope that won't work because its not the LKCU (current User registry Hive) - I'll msn Hamish and ask him to add a commandline parameter for it.
Old Apr 15, 2010 | 12:38 PM
  #1311
wip's Avatar
wip
2.7.0031 here...
(apologies in advance if this has been fixed in a later version, but I haven't seen anyone mention it)
Apart from the below problem, it's awesome
First 'bug' I've found is in the graphing vs maptracer.
Maptracer displays the name of the logged items correctly, whereas the grapher doesn't?
(FYI, this was simply a test, logged with just the ignition on, no engine running. It does the same when it's running though...)
Pic below:
Old Apr 16, 2010 | 05:30 AM
  #1312
leecavturbo's Avatar
they have to be in the same order and the load must be logged and correctly defined or it will have you running round in circles
Old Apr 16, 2010 | 09:55 AM
  #1313
wip's Avatar
wip
Same order?
That only used to apply to certain items like PW & DC% when one value is used in the calc for the next.
Never had any problems previously and I've tried both ways of editing the items (data xml and through the EvoScan list).
Never touched the load in this version as it appears to have been fixed.
(my old version had 1 byte renamed to EcuLoad and EcuLoad renamed to EcuLoadOLD iirc)
Either way, other entries are obviously wrong, but only on the graph, NOT on the maptracer.
Old Apr 16, 2010 | 11:48 AM
  #1314
mlocatel's Avatar
I had a similar problem and I signaled it to Hamish
Old Apr 16, 2010 | 10:11 PM
  #1315
mfr122887's Avatar
Is it possible to make a peak and hold gauge in the Gauge creator?
Ideally I would like to display the max boost of the current session of positive boost. So if I go WOT and hit 25lbs it would show that, then I let off and get back on it part throttle and hit 15lbs, it would display that. Basically anytime the boost went positive it would reset the peak value. The Blitz boost controllers do this and I think it is a great feature.
Old Apr 17, 2010 | 06:55 PM
  #1316
autoxer_minh's Avatar
I've tried but couldn't make a peak and hold gauge. If anyone's been able to figure this out, I'd be interested also.
Old Apr 17, 2010 | 07:36 PM
  #1317
SiC's Avatar
SiC
Peak hold gauges are only available in the GPS/Nav version of Evoscan. I'm sure Hamish will implement it into the PC version soon.
Old Apr 18, 2010 | 01:17 AM
  #1318
evoscan's Avatar
Silver Sponsor
Hey Dudes, whats up... i'm back to help you guys out. A lot of new stuff coming out this year for EvoScan and EvoScan Standalone Unit.
Old Apr 18, 2010 | 05:04 AM
  #1319
welcome back that man^
what goodies have you for us
Old Apr 18, 2010 | 06:07 AM
  #1320
metalsaber's Avatar
Any anticipated release date for EvoScan 2.7?
