stalling issues
Old Aug 26, 2010 | 11:31 AM
  #46
Boosted Tuning's Avatar
Originally Posted by PlanoEvo
thanks for your timing trick it seemed a help a lot with the recovery however with that it would still stall especially when pushing the clutc in at 5K. Only after i changed mivec did the stalling stop entirely
Nice. Yep MIVEC changes help too.
Old Aug 26, 2010 | 11:32 AM
  #47
Raptord's Avatar
What's this timing trick you speak of? Or is it "private"?
Old Aug 26, 2010 | 11:39 AM
  #48
yes, sorry. Im not handing it out anymore.
Also, if you have a IX, its seems from PlanoEvo's post, that MIVEC changes help more to eliminate the stalling.
Old Aug 26, 2010 | 01:55 PM
  #49
Smoothgangsta's Avatar
Raptord, adjust your 3 high octane ignition maps (i.e. TIMING) to the following to help with recovery.
Also, to quote "For those with cams, it is recommended to change your timing between 0 - 1500rpm between Load 0 - 50/60 to around *11 to *14" -
Post 50 https://www.evolutionm.net/forums/8450656-post50.html
From thread https://www.evolutionm.net/forums/ec...ml#post8450656
Let us know if that helped.
Old Aug 26, 2010 | 05:57 PM
  #50
Originally Posted by Smoothgangsta
Raptord, adjust your 3 high octane ignition maps (i.e. TIMING) to the following to help with recovery -
0 10 20 30 40 50 60
0 | 10 10 10 10 10 12 15
500 | 10 10 10 10 10 12 15
750 | 10 10 10 10 10 12 15
1000 | 10 10 10 10 10 12 15
1250 | 12 12 12 12 12 15 17
1500 | 15 15 15 15 15 17 21
or (copy/paste)
Sorry, but thats not the trick Im talkin about.....
Old Aug 26, 2010 | 07:35 PM
  #51
I don't think anyone is asking for you to review logs and build a complete tune, I myself would be curious to see what you know that is better that would work as far as timing goes.
Please help some fellow owners out.
Old Aug 26, 2010 | 07:46 PM
  #52
Appauldd's Avatar
Watch it....Jay likes his little "secrets". I got slapped on the pee pee for "disclosing"
Old Aug 26, 2010 | 07:47 PM
  #53
PlanoEvo's Avatar
To help with recovery increase the timing as it goes lower
500 14 14 14 14 14
750 13 13 13 13 13
1000 12 12 12 12 12
1500 10 10 10 10 10
Thats the trick! Now raise your mivec to 3.2 at 500 and 4.2 at 750 4.6 at 1000
Thats what worked for me not one stall since I did these steps!
Old Aug 26, 2010 | 07:48 PM
  #54
Since you said "Please"
In this example, the car idles at 1000rpm and 40 load
Old Aug 26, 2010 | 07:55 PM
  #55
500 14 14 14 14 14
750 13 13 13 13 13
1000 12 12 12 12 12
1500 10 10 10 10 10
This sounds like a great trick too. Never seen people use MIVEC at idle to prevent stalling.
Old Aug 26, 2010 | 07:56 PM
  #56
Ahhh, ok I see the logic now. I really appreciate you guys offering up the logic and insight in regards to the information...
Much thanks!
Old Aug 26, 2010 | 08:00 PM
  #57
PlanoEvo's Avatar
it works combined with the timing raised in tandem. Not one stall since I used these together and I've tried really hard lights on ac full blast 5K clutch no stall! One more tool to make people independent of over priced tunes Dont get me wrong some people need tuners some dont thats all peace!
Old Aug 26, 2010 | 08:01 PM
  #58
You only got slapped because you gave me your word you wouldnt disclose my "trick". Then you did the first chance you got.
PlanoEvo, on the other hand never gave me his word (cuz I didnt tell him). So he is
Old Aug 26, 2010 | 08:08 PM
  #59
Appauldd's Avatar
OH BOY...here we go again. Can you just drop it already? ? ?
Now that YOU look like the "Guru" (wasn't that the word you used for me?) you should be happy.
Let it go.
  #60
Well, I do understand not wanting to disclose things when you invest time and effort to try ALOT of different things and then find a solution to an issue and then people are asking for all that effort. Anyway, I just want to say thanks to all 3 of you for being kind enough to share and post the info. I am going to try some of those changes over the weekend and observe the results and will report back next week sometime.
Much thanks.
