The 3xMAP/MAF tables
Old Sep 16, 2010 | 07:41 PM
scheides's Avatar
EvoM Moderator
Gah I just cannot wrap my head around the math....
If you simplify yours to: "StockXMAP in kPa" toexpr="((x*.67)+0.5) / 2" frexpr="((x*2)-0.5)*.67"
and then start to weigh it against the Evo8/9 MAP16bit scalings:
https://www.evolutionm.net/forums/ec...y-patches.html
I just cannot get the math to work out. There must be some other variable or offset that I'm not seeing...cheeky bastard! LMK, I have a 4-bar sitting in my arm wrest
ps--sorry I didn't see this till today; work's been a nightmare
Old Sep 16, 2010 | 08:07 PM
tephra's Avatar
Code:
<scaling name="StockXMAP in kPa" units="StockXMAP in kPa" toexpr="((x*2556/3800)+0.5) / 2" frexpr="((x*2)-0.5)*3800/2556" format="%.2f" min="-15" max="35" inc="0.05" storagetype="uint16" endian="big"/>
<scaling name="Omni4barMAP in kPa" units="Omni4barMAP in kPa" toexpr="((5*x/1023)/0.012105) + (0.00842/0.002421)" frexpr="(x-(0.00842/0.002421))*0.012105*1023/5" format="%.2f" min="-15" max="35" inc="0.05" storagetype="uint16" endian="big"/>
The StockXMAP in kPa is TAKEN FROM THE ECU CODE... So hopefully Mitsu got it right
The Omni4bar is taken from the Omni information and calculated from there...
Old Sep 16, 2010 | 08:16 PM
murlo26's Avatar
Man, you still haven't gotten that 4bar, lol. Jon is taking forever
Hopefully it happens in a week or so, I was going to ask for the scalings again soon, going to need them in two weeks prolly.
Old Sep 16, 2010 | 08:18 PM
tephra's Avatar
Yeah sorry man
There is another table which will require the same work, but its not as important..
I will start a new thread as soon as I can
Old Sep 16, 2010 | 08:19 PM
murlo26's Avatar
Originally Posted by tephra
Yeah sorry man
Cool, much obliged Tephra
Any ETA on the 4 bar getting there? Did Jon ship it yet?
Old Sep 16, 2010 | 08:56 PM
xPRimNT's Avatar
Ok, so I'll just ask. Obviously if you're working on a 2.2L or something, you'll want to scale these tables to adjust for the new load/cylinder.
However, when else should we be adjusting this? What I'm really going after is how/if to use these tables to fix that load dip from quick spool. If we're still on stock engines, should we even tough this (unless swapping for 4bars )?
Old Sep 16, 2010 | 09:11 PM
scheides's Avatar
EvoM Moderator
I don't think this will change much in regards to your load dip issue; this is basically going to allow proper rescaling of the engine air metering system.
Old Sep 16, 2010 | 10:11 PM
tephra's Avatar
2.2 should increase this by 10%... or at least that is what seems to work...
im still working on the load dip issue...
Old Sep 16, 2010 | 10:59 PM
xPRimNT's Avatar
You're already my ECU Hero, but if you figure out the load dip, you'll move up past Mother Teresa for people I respect. It's that serious.
Also more than happy to test, since I actually have the problem. I don't know if the Load Dip is entirely relevant to these tables, so I'm going to stop cluttering this thread.
Old Sep 16, 2010 | 11:09 PM
nonschlont's Avatar
Do we have these maps for VIII's and IX's? My load dips right after peak too...
Old Sep 16, 2010 | 11:10 PM
tephra's Avatar
No.
Old Sep 20, 2010 | 01:29 PM
kozmic27's Avatar
Anyone have the MAF/MAP table definitions for the 2008 they'd be willing to post? I have them for the 2010's, but not for the 2008's for some reason.
Thanks.
Old Sep 20, 2010 | 05:51 PM
Golden's Avatar
Scalings may need to be updated to anything new that Tephra has posted lately.
[code]
<table name="MAF Scaling Part 1" address="5753a">
<table name="Volts" address="615ea"/>
</table>
<table name="MAF Scaling Part 2" address="57592">
<table name="Volts" address="61642"/>
</table>
<table name="MAF Scaling Part 3" address="575ea">
<table name="Volts" address="6169a"/>
</table>
<table name="MAP Mass Air Flow Scaling #1" address="60454">
<table name="MAP" address="62a2e"/>
<table name="RPM" address="62a02"/>
</table>
<table name="MAP Mass Air Flow Scaling #2" address="60178">
</table>
<table name="MAP Mass Air Flow Scaling #3" address="5fe9c">
</table>
[code]
Old Sep 21, 2010 | 02:24 AM
tephra's Avatar
4bar has arrived
install and writeup this weekend
Old Sep 21, 2010 | 04:20 AM
Fourdoor's Avatar
My RA has been a pain in the @ss ever since I put in a set of cosworth cams. They obviously affect the VE of the engine... would I be better off using the numbers from an EVO X in these tables instead of the stock RA numbers?
Keith
