The 3xMAP/MAF tables
Old Jan 3, 2014 | 02:37 PM
  #151
mrfred's Avatar
Originally Posted by awdgsx91
Bringing back a really old thread but I flowed a stock EVO X maf so maybe this data will help you figure out some of the maf units etc.
The maf was flowed with a 1K pulldown because it seems as the ECU has this in the maf circuitry.
ignore the calc error column
Awesome data. That's some pretty impressive error at low flow rates. The report says that this test was run with a stock airbox. Is that correct? What intake pipe was used?
Old Jan 3, 2014 | 04:50 PM
  #152
awdgsx91's Avatar
The error numbers aren't really relevant they are based on a generic curve fit equation I used. I have not curve fit the evolution maf yet.
It was flowed with the stock airbox and filter. Things downstream of the maf do not affect the flow readings. the maf and airbox were flowed without the intake tube.
Old Jan 3, 2014 | 05:39 PM
  #153
mrfred's Avatar
Isn't the MAF in the intake tube?
Old Jan 3, 2014 | 05:58 PM
  #154
RazorLab's Avatar
I think you guys are both saying the same thing. The MAF is in it's own housing, which happens to be a tube form. However the actual induction tube, the accordian style rubber piece is after the MAF housing.
Old Jan 5, 2014 | 08:18 PM
  #155
kozmic27's Avatar
I'm trying to come up with a blow-thru maf solution for the evo X. Need someone to do some testing with a maf.. Here is the transfer function for the maf they would be using..
http://www.pmas-maf.com/resources/PFLHPXN2GT4.xls
This should be doable if you correct the MAF IAT load modifier to a range that the MAF IAT sensor would actually see. I don't know how the ecu would react to a drastically high MAF IAT. If a DTC threshold exists for MAF IAT it might need to be adjusted or disabled. Someone who actually does dis-assembly could probably find it. Or there is the "try it and find out" methodology.
We do this on n/a Nissans all the time when converting them to forced induction. It works pretty well, other than the ecu not liking some of the really high IAT readings.
tephra
70
Jul 11, 2024 12:59 AM
itzwolf
Mar 15, 2022 06:18 AM
darkeye
Sep 12, 2021 02:09 AM
Piper747
Oct 9, 2010 01:14 PM
chmodlf
Jan 31, 2008 05:50 PM
