The 3xMAP/MAF tables
Old Jul 19, 2011 | 10:25 PM
  #91
lanasa's Avatar
OK after adding that now I am getting an error??
Originally Posted by razorlab
Now that the scalings are in your XML you need to make sure those tables use them. Either change it in the XML by hand or in Ecuflash via the drop downs.
If via the XML, should look like this:
<table name="MAP based Load Calc #1 - Hot/Interpolated" category="Fuel" address="YOUR ADDRESS" type="3D" level="2" swapxy="true" scaling="Loadify">
<table name="MAP" address="YOUR ADDRESS" type="X Axis" elements="19" scaling="StockXMAP in psig"/>
<table name="RPM" address="YOUR ADDRESS" type="Y Axis" elements="19" scaling="RPM"/>
</table>
File Type: hex
Old Jul 19, 2011 | 10:27 PM
  #92
lanasa's Avatar
comment deleted
Old Jul 19, 2011 | 10:28 PM
  #93
RazorLab's Avatar
What error?
You didn't just copy past that XML I posted right?
If you do, you need to put your correct addresses in the part where I had:
Old Jul 19, 2011 | 10:30 PM
  #94
RazorLab's Avatar
Here I will make it easy, just replace your xml for those tables with this:
Code:
  <table name="MAP based Load Calc #1 - Hot/Interpolated 2010" address="6058a" category="Fuel" type="3D" level="2" swapxy="true" scaling="Loadify">
    <table name="MAP" address="62c88" type="X Axis" elements="20" scaling="StockXMAP in psig"/>
    <table name="RPM" address="62c5c" type="Y Axis" elements="19" scaling="RPM"/>
  </table>
  <table name="MAP based Load Calc #2 - Cold/Interpolated 2010" address="60288" category="Fuel" type="3D" level="2" swapxy="true" scaling="Loadify">
  </table>
  <table name="MAP based Load Calc #3 2010" address="5ff86" category="Fuel" type="3D" level="2" swapxy="true" scaling="Loadify">
  </table>
Old Jul 19, 2011 | 10:36 PM
  #95
lanasa's Avatar
After adding <table name="MAP based Load Calc #1 - Hot/Interpolated 2010" address="6058a" category="Fuel" type="3D" level="2" swapxy="true" scaling="Loadify">
</table>
</table>
</table>
I got that error thats attached
Attached Thumbnails The 3xMAP/MAF tables-screenhunter_04-jul.-20-01.32.jpg
Old Jul 19, 2011 | 10:43 PM
  #96
RazorLab's Avatar
You have a misplaced / fubared string in your XML file somewhere, probably line 161
  #97
lanasa's Avatar
ok I got it working.. I fixed the line that was messed up. I dont see any new tables. I still see the
MAP Mass Air Flow Scaling #1
MAP Mass Air Flow Scaling #2
MAP Mass Air Flow Scaling #3
But there is now change to them from before
Old Jul 19, 2011 | 10:51 PM
  #98
RazorLab's Avatar
What XML did you put what I posted in #94
Old Jul 19, 2011 | 10:53 PM
  #99
lanasa's Avatar
I just deleted and used a fresh copy. I guess it was a typo. I added the one you posted
Old Jul 19, 2011 | 10:57 PM
  #100
RazorLab's Avatar
Yes, but which XML filename?
Old Jul 19, 2011 | 10:59 PM
  #101
lanasa's Avatar
Attached is my xml base10 file
File Type: zip
Old Jul 19, 2011 | 11:01 PM
  #102
RazorLab's Avatar
You need to put it in your 55570006.xml file
Old Jul 19, 2011 | 11:05 PM
  #103
lanasa's Avatar
I added
<scaling name="StockXMAP in psig" units="StockXMAP in psig" toexpr="((x/4)*0.19347)-14.5" frexpr="((x+14.5)/0.19347)*4" format="%.2f" min="-15" max="35" inc="0.05" storagetype="uint16" endian="big"/>
and
<scaling name="Loadify" units="%" toexpr="(x*10/512)*10/32" frexpr="(x*32/10)*512/10" format="%.1f" min="0" max="300" inc="1" storagetype="uint16" endian="big"/>
</table>
</table>
</table>
I added it to the end this time and it worked.
Old Jul 19, 2011 | 11:06 PM
  #104
lanasa's Avatar
Ok I will take it out and add it..
Old Jul 19, 2011 | 11:25 PM
  #105
lanasa's Avatar
Thanks a bunch. I got her working. Now I am going to up her 15% for the 2.3 ltr
Attached Thumbnails The 3xMAP/MAF tables-screenhunter_05-jul.-20-02.13.jpg   The 3xMAP/MAF tables-screenhunter_06-jul.-20-02.14.jpg
