Logging with the (Beta) Standalone Tactrix Cable Logger (No More Computer!)
Old Oct 29, 2010 | 12:03 PM
  #106
fostytou's Avatar
EvoM Community Team
Originally Posted by hediki12
I'm thinking all the request I've seen ecu based are 2digits or 5 like the evo x (I think its 5 can't remeber off hand) maybe the 100 set are "read from cable" worth a shot though. I appologize for pming that and not posting it publicly first . Thnx for putting it up . Pain in the *** from a phonne I can barely use lol
No problem, let us know if it works!
Old Oct 31, 2010 | 02:11 PM
  #107
GST Motorsports's Avatar
I couldn't seem to find an answer, does this also support CAN request logging as well?
Example: CAN28-0
- Bryan
Old Oct 31, 2010 | 04:38 PM
  #108
tephra's Avatar
nope.
which reminds me - I need to ask Colby to add some more logging strings
Old Nov 2, 2010 | 07:08 PM
  #109
Originally Posted by tephra
nope.
bummer
It's capable though right? Just not able yet?
- Bryan
Old Nov 2, 2010 | 07:34 PM
  #110
tephra's Avatar
He is in the process of enabling it...
Old Nov 2, 2010 | 08:09 PM
  #111
hediki12's Avatar
ok i tested it free air using request 101 and 101 equations x, x*14.7 and x/14.7 non of them came close ... they were stagnant ... i was at lease looking for a lc1 lean output on the evoscan but nothing.i guess it isnt so simple haha. if anyone can chime in please help im not software savy . i also tried logging the comport that the 2.0 is connected to and still no luck. stagnant 0 as the out put.
Old Nov 2, 2010 | 08:46 PM
  #112
Beeble's Avatar
Example: CAN28-0
heh i just emailed Dave re: this... mate if you see this first, ignore
was reading the other forum, should have checked here first!
can someone confirm the latest firmware numbers for me :
I'm on API version 04.04 , DLL version 1.00.3017 (Apr 8 2010) , Firmware version 1.10.3020
EDIT - that's on ECUFlash 1.43.3000
when i plug in the Tactrix to the laptop and go to ECUFlash licensing, and hit the "apply" button, thats what it spits out at me.
do i need to put something in the "Add License" window first?
Old Nov 2, 2010 | 10:14 PM
  #113
tephra's Avatar
I am using EcuFlash 1.43.3150
You shouldn't need to touch the licensing at all.
Whats your actual problem?
Old Nov 2, 2010 | 10:27 PM
  #114
Beeble's Avatar
LC1 logging via stereo jack to OP2.0... i get nada
i think i have this right
type=inno
paramname = LC1.afr
paramid = 0x0101
scalingrpn = x,14.7,*
if that's right, maybe i need to look at my stereo cable?
Old Nov 2, 2010 | 10:29 PM
  #115
tephra's Avatar
OIC... Yeah I dont use the LC1 built in logging - I hook it up to the ECU and log via analog..
however you need to be really careful about wiring to do that properly...
Old Nov 2, 2010 | 10:35 PM
  #116
Beeble's Avatar
yeah i was going to wire it in when i installed it, but bailed out thinking "I'll only ever use serial and a laptop".
:facepalm:
Laptop isn't much help on the track, it's kind of a large projectile
I'll fork out the few $$ to get a new cable and see how i go. The one i have is pretty beaten up.
Old Nov 2, 2010 | 10:47 PM
  #117
tephra's Avatar
Maybe just try logging ONLY that channel - ie remove the rest of the config and see if it works...
Old Nov 2, 2010 | 10:53 PM
  #118
Beeble's Avatar
hrmm ok I'll give it a shot after work.
Old Dec 7, 2010 | 08:46 AM
  #119
fostytou's Avatar
EvoM Community Team
type=inno
paramname = LC1.afr
paramid = 0x0101
I solved my problem, and probably yours. The section for logging AFR needs to be before the start/stop parameters. Once I moved it above those everything for my UEGO worked great!
Old Dec 14, 2010 | 09:26 PM
  #120
fostytou's Avatar
EvoM Community Team
Here is my Solid, working evo X mode23 logcfg with various start/stop options and extra logging parameters including AEM serial
http://thefrost.net/randomfiles/tuni...214.logcfg.txt
I tried to keep the shortnames in-line with evoscan as to keep it easy to pull up there. I'm interested to see how these long logs pan out when I AWK my way through them!
