AEM EMS Get tuning help for your AEM EMS system.
EMS daily as driver
Old Sep 16, 2005 | 10:04 PM
ctx2000's Avatar
EMS as daily driver
is there any issue for daily driver? stop n go and traffic with A/C on?
Old Sep 17, 2005 | 08:45 AM
ninjadoc's Avatar
No issues as a daily drive once you get hot and cold start working right and idle adjusted. No problem with AC.
Old Sep 17, 2005 | 04:12 PM
Bom's Evo's Avatar
fine for me. took a trip to ohio from NJ and back. on AEM for like 5 months now. going through my first winter with it this season too. im about 15k miles a year driver.
Old Sep 17, 2005 | 05:58 PM
c kim's Avatar
Only concern I would have is getting the car tuned for different weather climates. You'd need to retune for warm and cold climates but seeing that you live in Georgia, you shouldn't be concerned. It stays fairly warm there all year round?
Old Sep 17, 2005 | 06:02 PM
Precision Dyno's Avatar
You shouldnot have to tune again in different climates.
If you do then the tune was not right from the beginning.
If you have any problems with your system give us a call.
(856) 4952227
Old Sep 17, 2005 | 06:17 PM
Mooshu1221's Avatar
can the car still pass the inspection with the ems installed. or do u have to pull it out and put the stock one back in to get the car inspected.
Old Sep 17, 2005 | 06:20 PM
SilverEvo8owner's Avatar
depends if it is an OBD II check or tailpipe
The car would probably run even cleaner with an EMS.
Old Sep 17, 2005 | 09:19 PM
ctx2000's Avatar
when the vehicel is in motion, the A/C on i can't maintain in around 2000rpm (jerking), cause is gona do up n down from 1500 rpm to 2000 rpm about 2 or 3 time and if you just let go the gas, the rpm is down a little slower after 1500 down to 1000 without A/C.
is this right?
Old Sep 17, 2005 | 09:23 PM
awddyno's Avatar
your idle should only go up by 200rpm or so, check your setting for your a/c under settings
Old Sep 18, 2005 | 07:00 AM
ninjadoc's Avatar
It'll pass tailpipe. It will not pass OB2. Some of the units the states use for OB2 testing( such as Ohio) have problems with the stock ECU so they default to tailpipe testing.
Old Sep 18, 2005 | 01:52 PM
is this right?
It needs to be tuned for proper idle. That is not correct.
Old Sep 20, 2005 | 12:43 AM
ctx2000's Avatar
for NICK at PRECISION DYNO thanks for the offer to help me out with my problem, but now all is already solve. DOUGH at TOPSPEED solve the problem.
now the car run very smooth and the car pull so strong.
LocoLT1
26
Dec 28, 2012 08:19 PM
ryanz_here0427
14
Nov 11, 2010 11:49 AM
jayel
Aug 18, 2008 07:46 PM
ride22
For Sale - Cars For Sale
Apr 22, 2007 06:46 PM
dp2580
Aug 15, 2004 08:58 AM
