AEM EMS Get tuning help for your AEM EMS system.
Which MAP and IAT sensors work with the AEM EMS?
Old Oct 30, 2005 | 01:04 PM
ct9a gsr's Avatar
Question Which MAP and IAT sensors work with the AEM EMS?
I'm trying to find alternatives to the standard sensors AEM sells for outrageous prices to use with my EMS...
Which sensors can we use and what do we need to use to adapt them to work with the AEM? I was hoping I could use just a normal GM 3bar MAP sensor instead of the AEM's 3.5bar MAP sensor. If so, which part#('s)?
Any and all info would be helpful on this topic... thanks. =]
Old Oct 30, 2005 | 04:13 PM
ct9a gsr's Avatar
*bump*
also, any vendors on here sell cheap MAP and IAT sensors for the AEM?
Old Oct 30, 2005 | 05:02 PM
ltwayner's Avatar
You can use a GM MAP sensor cause that's what I have. Don't know the part#. Works like a charm
Old Oct 31, 2005 | 06:38 AM
Inn-Tune's Avatar
If you download the free AEM EMS software from the AEMPower.com website and go in the Setup -> Sensors menu and open up the wizard for each sensor, you'll get a list of all the supported sensors. AEM supports several GM MAP sensors by part number for instance. This way you can see all of them.
You can, of course, use any sensor you like if it's 0-5V and you have the calibration data, but using one from the Wizard makes things a lot easier.
-Mike
Old Nov 21, 2005 | 07:35 PM
TheGVR4kid's Avatar
is the GM 5-bar going to be a bltch to tune with?
Old Nov 26, 2005 | 08:03 PM
VIIImylunch's Avatar
Is there some where locally they carry the GM AIT sensor?
Old Nov 27, 2005 | 07:28 AM
kcevo's Avatar
Yes, your GM Parts dealer.
Old Nov 27, 2005 | 07:34 AM
Precision Dyno's Avatar
Where are you located? I can have them shipped to you tommorow if you like.
Old Dec 12, 2005 | 08:05 PM
TrinaBabe's Avatar
You should be able to technically use any sensor as long as it is 0-5v. You just would need to manually calibrate it.
Old Jan 14, 2006 | 01:33 AM
sleeperevo8's Avatar
aem map bar?
what is the difference between a 3.5 and a 5 bar map sensor?
Old Jan 14, 2006 | 11:58 AM
levo2nr's Avatar
the 5 bar map hold more boost alot more boost
Mitchubishievo
10
Feb 7, 2011 07:03 AM
shunderwunder
AEM EMS
Jun 14, 2008 07:06 PM
Santiago@AMS
Automotosports - Illinois
27
Dec 27, 2006 07:13 PM
silverEVO8
18
Nov 17, 2004 09:01 PM
metaphysical
10
Oct 26, 2004 12:04 PM
