AEM EMS Get tuning help for your AEM EMS system.
idleing problem, please help!!
Old Jan 5, 2006 | 04:08 PM
siQness's Avatar
well i just got my car fixed since the car wouldnt even crank at all, but now when the car turns on, the rpms just drop, and the car shuts off, so the whole time, u have to keep reving the car , or the car will stall, anyone know what this problem is
Old Jan 5, 2006 | 04:17 PM
IEXCELR8's Avatar
Does it still stall after it is warmed up? Could be a warm up enrichment table. Also look at the start fix on here. Maybe post a cal file so someone could look at it.
Who tuned it for you to get it fixed?
VTECH8TR's Avatar
Where are you located in florida?
Old Jan 5, 2006 | 04:18 PM
platinumspecv's Avatar
probably too much fuel. who initially tuned your car?
Old Jan 5, 2006 | 04:19 PM
siQness's Avatar
it still does it when its warm, i live in coral springs. titan tuned it
Old Jan 5, 2006 | 04:23 PM
VTECH8TR's Avatar
Titan knows how to tune a car. Did you go back to them? I think you should go back to them IMO so they can help you out. We can help you, but since it was professionally tuned they should help you fix it. The AEM is a powerful standalone and one mistake can take out your motor.
Old Jan 5, 2006 | 04:25 PM
IEXCELR8's Avatar
+1
Old Jan 5, 2006 | 04:31 PM
yea man I agree with Luis. Whoever tuned your car.... you go back to them
Old Jan 5, 2006 | 08:17 PM
macsperformance's Avatar
I agree you need to take the car back to them if it is a tuning issue. I did notice that you said you just got the car fixed. What work was performed on the car and did it exhibt the same problem before the car was worked on or did it start after?
If you can not get the car back to them now I would be more than happy to look at your calibration file and give you some advice on what to do. my email is:
macsperformance@gmail.com
Chris Macellaro
Old Jan 6, 2006 | 11:23 AM
strikethree's Avatar
Is your IAC working? I have seen similar behaviour when the Idle Air Control valve is non-functional.
strike
nickracer9's Avatar
is the iac plugged in?
Old Jan 6, 2006 | 07:43 PM
siQness's Avatar
they fixed the problem, they rewired the aem, they said it was messed up, anyways i have another problem few months ago, after i got ****ty plugs, i hit full throttle and my car will just shut off and my car will roll, anyone know why it shuts off, is it cause of the spark plugs
Old Jan 16, 2006 | 06:41 PM
TrinaBabe's Avatar
The plugs alone wouldnt do it... I would assume it is the same wiring problem as before. Plugs will make the car misfire and buck at WOT but not turn off.
Just so you know, there is something screwy with my EMS... it will not control the IAC regardless of the settings... right now I just have it unplugged and use the BISS screw to adjust it. It doesnt idle when its real cold but once it starts to warm up it will idle. The warm idle is at around 1100-1200 which seems fine to me.
Old Jan 16, 2006 | 08:34 PM
Have you tried messin with the warmup enrichment table? I had that problem when the car was cold..it would not idle. Too much fuel. Remove some fuel and try.
RoryMarckese
Feb 17, 2011 10:28 AM
lancer2010
Lancer Tranny/Drivetrain Tech
Oct 12, 2010 06:40 AM
xxxevo8xxx
AEM EMS
13
May 31, 2008 03:03 AM
JordanS4
32
Dec 14, 2006 04:52 PM
mb32
19
Mar 9, 2006 01:33 PM
