AEM EMS Get tuning help for your AEM EMS system.
AEM uego question
Old Dec 6, 2005 | 04:24 AM
sleeperevo8's Avatar
Unhappy AEM uego question
its really cold where i live right now and i was wondering could the cold cause my AEM uego to read all funny. no matter have warmed up the car is the gauge always reads rich. when i do bout half throttle or full throttle the gauge will go to 13.3 then drop down to nothing in like 2 seconds i now my cars not running rich cause my other A/F gauge is reading just fine that runs off the ECU and i was working just fine before it got cold. could it be the cold the causing to gauge to do this?
Old Dec 6, 2005 | 04:32 AM
AndyBandy's Avatar
yeah mine seems to spike more in cold weather. like it fluctuates from like 1-2k rpm and im not sure what is making it spike. (this happens when im idling at like a stop light or something) im not sure if this is related but do you mean goes to 13.3 and then to nothing while still holding the throttle? or do you let off?
Old Dec 6, 2005 | 05:28 AM
when holding throttle or flooring in does the sam thing jumps up then goes right back down
Old Dec 6, 2005 | 06:04 AM
VTECH8TR's Avatar
I am moving this to the AEM forum.
Old Dec 6, 2005 | 07:09 AM
GTVEVO's Avatar
It sounds as if the Wideband sensor is damaged. When the sensor gets damaged it will read low values and usually a very narrow range kind of like what you are discribing. Cold weather should not make a difference is the sensor is in good working order and hooked up correctly. Just keep it in mind.
Old Dec 7, 2005 | 12:40 AM
i'll see what a new sensor would cost the car did sit for like a month when i was over seas it might hav just went bad
dspize
Jul 26, 2014 05:24 PM
jbuhrman
Feb 3, 2014 06:45 PM
ugakirk
Apr 29, 2012 12:57 AM
maradits
Apr 3, 2012 05:03 PM
ErnGotti
Apr 25, 2011 04:24 PM
