Need a little more explanation on wiring wideband into ems.
Install into pin 76 of the ECU harness. Depin, cut the wire and splice ect
Ive got LM-1...
What exactly am I splicing into there off of my wideband is what I want to know.
Thanks
Ive got LM-1...
Thanks
Go into the lm-1 programmer software. That will tell you what wire is analog 1 & 2. Choose what analog you want for whatever o2 sensor then solder or depin. Then set the 0 and 5volt to the afrs you want then go to the 02 #1 cal. table in aem pro and put those #s in the 0 & 5volt spots. Then highlight the entire table. Right click and hit calculate. You can do those steps however you want. Im not so good at explaining.
A forge mbc. Which has way too many increments. And if i put the hard spring in the lowest setting is 25psi with the external gate. Just cant win. I think i might put my old school hallman back in. Those things look like hell but can go through a nuclear war and still work.
evotris
Jul 7, 2008 09:44 PM
