AC control lights
Old May 29, 2004 | 08:41 AM
cautiontext's Avatar
Dash Lights
I need some advice on what is wrong with the lights in the AC control panel. I installed the reverse indiglo guage and now they wont work. I spliced the green and white wire and the black and yellow to the positive wire of the guage. Then I used the solid black wire to the negative ground of the guage. I think I might be using the wrong wire as a the ground. Does anyone have any suggestions on how to fix this? I checked all the fuses and they are good, I even disconnected the negative terminal from the battery during the whole splicing process. Please help, thanks guys....
Old May 29, 2004 | 09:09 AM
SOMEONE
Old May 29, 2004 | 09:53 AM
Old May 30, 2004 | 12:09 PM
guess no help?
Old May 30, 2004 | 07:16 PM
bump
Old May 30, 2004 | 07:31 PM
bobaab's Avatar
ground = any metal point on the car. if that helps any
Old May 30, 2004 | 07:33 PM
yellow_lancer's Avatar
i dont think anyone did the reverse indiglio gauges that many times to realize how you messed up. im sorry because i couldnt be of help... but all i can say is take it to a shop and hopefully they can help out...
but in other note... college park? i live in beltsville..
Old May 30, 2004 | 07:37 PM
Thanks for the replys... I emailed sportracing and am waiting on a response. I figured I would have to take it to a shop....
Old Jun 2, 2004 | 05:48 AM
Well I finally figured out what the hell was wrong. I will finish up on the work today and post some night pics of what I was trying to do. In short, I had to end up resodering some wires and changing my wiring method. If anyone needs help on this install just pm me. I have a better understanding on the process of how to install correctly. Problems like these make it all worth the head scrattching becasue you learn alot in the end.
supersnow
May 25, 2016 02:53 PM
stefenboy
May 20, 2016 07:51 PM
otter
04-06 Lancer Ralliart How To Requests / Questions / Tips
67
Oct 18, 2010 09:32 AM
TREVORSEVOVIII
Jan 6, 2008 10:07 AM
crasher
Jan 31, 2007 07:50 AM
