AEM EMS Get tuning help for your AEM EMS system.
Problems on Spool up
Old Apr 9, 2006 | 08:07 AM
VIIImylunch's Avatar
My car is seeming to have issues on on spool up. If ease into the gas from low to high rpm the car doesnt have issues, but if I floor it the car seems to pop, and it almost feels like fuel cut, and then grabs and goes.
any help would be great.
Old Apr 9, 2006 | 08:20 AM
feldguy's Avatar
same problem here. abrupt fuel cut is what I thought, but it vibrates through the whole damn car.....
Old Apr 9, 2006 | 07:07 PM
EVOONYOASS's Avatar
Mine does the same thing but if I change my plugs it goes away for awhile. Lately I have been changing the plugs every 500-700 miles because of this problem.
I thought my problem had to do with the methanol injection.
Old Apr 9, 2006 | 09:00 PM
I thought it was in a problem in the fuel map, but we played with it for hours the other day and it didnt help.
Old Apr 10, 2006 | 06:31 AM
feldguy's Avatar
Anyone else?
I have this problem, running 20psi spiking to 21 (ive managed to get it to hold to 17.5 till redline, stcok VIII turbo
If i am lugging the motor down this does this almost predictably......I'll have it at 3500 revs in 4th and if i got WOT up a hill, it winds up with a large thud...almost like the motor popped or,
more like the blow off valve or a positive pressure charge pipe letting loose...
Old Apr 10, 2006 | 01:00 PM
Mase's Avatar
do you have any logs of the AFR while this happens.
sounds like its either going pig rich or very lean.
either way, sounds like a bad tune possibly.
Old Apr 10, 2006 | 03:22 PM
silverofs's Avatar
is your knock control on??? how old are your plugs?? gap???
Old Apr 10, 2006 | 03:38 PM
GTVEVO's Avatar
please dont take it the wrong way but log it and find out what the problem is. You have a very good tool and chances are it is a problem with the tune. Like said above rich or lean during accel throttle changes at certian load and rpm. I have seen several tunes that have this issue becuase they are usually just tuned on the dyno and that is it.
Old Apr 10, 2006 | 04:08 PM
lancealott's Avatar
I used to have that same problem when I did some major upgrades on the TurboXS utech. We had major problems with my A/F Everything would be going smooth, then a little after 5000 rpm, my engine would pop and my nice hp and A/F would go to crap.
So I got fed up with the utech, pulled it out and spend money for the better AEM. Now I have the AEM with no problems, great A/F.
But.....since then I just installed the Perrin larger intercooler and the Helix piping system. Now occcasionally on high boost I may get a slight flutter at high rpms, barely noticeable, but going back to my great ol tuner again! No fear here, AEM is here. I love the system. Long bull sh*t story short.
+2, see your tuner.
