AEM EMS Get tuning help for your AEM EMS system.
starting fix for AEM EMS trouble
Old Nov 6, 2006 | 08:03 AM
AndyBandy's Avatar
I responded to the stickied post above, but its hard for everyone to see that I have posted a reply to that one, so here goes.
I’ve just begun to play around with the EMS myself and am trying to input the starting fix. I put the tooth time to 500 and check the box that reads “sync early” then I save. When I check to see that my update saved, it drops my tooth time to 50 ms, but it leaves sync early checked (which tells me it saved)
Anyone else have a similar problem with the tooth time?
Thanks guys!
-Andy
Old Nov 6, 2006 | 01:18 PM
kcevo's Avatar
Thanks guys!
-Andy
You have to hit the return/enter key when you make a change.
Old Nov 6, 2006 | 01:32 PM
AndyBandy's Avatar
i press save, then i cant remember the command, but i guess i didnt specifically hit "return", but i pressed the shortcut button that applys the command to the ecu. its not the same?
Old Nov 6, 2006 | 01:40 PM
kcevo's Avatar
When you make a change in an option box, like say in your case where you wanted it to be 500 instead of 50 then you will type in 500 and hit enter thus the change will take place. You will see in the bottom left hand of the status bar(bottom left of the screen) that it will be flahing "cal changed" in red, of course if you are making multiple changes this will be blinking until you save the file.
Old Nov 6, 2006 | 03:51 PM
AndyBandy's Avatar
thanks, i'll do that.
Old Dec 7, 2006 | 07:14 AM
32 psi daily's Avatar
f2 for quick save.
cerevo
AEM EMS
Dec 22, 2016 12:33 PM
TurbotrixRacing
AEM EMS
43
Dec 10, 2012 02:31 PM
Mad_SB
AEM EMS
Mar 14, 2008 04:56 PM
spoolinspyder
AEM EMS
31
Jun 29, 2007 01:15 AM
binh
AEM EMS
14
Mar 13, 2007 08:15 AM
