AEM EMS Get tuning help for your AEM EMS system.
Where is your map sensor measuring location?
Old Dec 7, 2006 | 11:24 AM
Aby@MIL.SPEC's Avatar
where on your plenum are you taking your map sensor measurement reading?
how long is your line length if using line?
is your plenum oem or aftemarket?
Old Dec 12, 2006 | 09:57 AM
David Buschur's Avatar
We use a billet aluminum map sensor mount in our cars/kits here. The mount takes the place of the factory map sensor and lets you put the AEM threaded sensor in it's place. Works the best as far as I am concerned. No hoses to blow off, o-ring seal.
Old Dec 12, 2006 | 01:35 PM
Spaceball 1's Avatar
Buschur has a very good set up be careful and lube the o-ring before putting it in. I cut the o-ring when installing mine
Old Dec 12, 2006 | 02:23 PM
althemean's Avatar
+1 for the BR adaptor. Have it, love it, made the install easy. You will read posts about it being close to the strut bar but it will never hit. Those people that say that have never installed/used it.
Old Dec 12, 2006 | 04:34 PM
jbrown's Avatar
I like the RRE setup. It's in the same location as the Buschur, but puts the sensor at a 90* angle so it looks better and doesn't get in the way of aftermarket strut bars.
http://www.roadraceengineering.com/p...r/IMG_1310.JPG
http://www.roadraceengineering.com/ems.htm
Old Dec 14, 2006 | 11:21 PM
Thanks guy's
Old Dec 15, 2006 | 09:35 AM
Research and copy...............the way of the import world.
Ours doesn't even come close to the strut tower bar there is no issue with that no matter who's bar you use.
Old Dec 27, 2006 | 08:04 PM
silverofs's Avatar
i have the switzer one in the stock map sensor location.. i'm sure it's just like the rre peice or buschur's..
