AEM EMS Get tuning help for your AEM EMS system.
A/C disabled, need help
Old Jan 3, 2007 | 03:58 AM
AndyBandy's Avatar
well apparently my last tuner disabled my A/C for no good reason, but when my new tuner tried to get it working again he couldn't get it to work. i was thinking two things....
a.) the compressor is broken (yes there is refrigerent in it)
b.) The new tuner couldn't remember the A/C code for the evo. there's a ton of codes but does anyone know which A/C code is the right one for the evo??? i'll try to be more specific when i get time to sit in my car and find the description.
Old Jan 3, 2007 | 07:16 AM
rraulston's Avatar
go to setup/air conditioner/options:
500
89
0.00
5.08
switch #2 gnd off
ls11
idle 5/6
disable
Ray
Old Jan 5, 2007 | 03:59 AM
AndyBandy's Avatar
well i tried the above (thanks ray) and the only thing that i had different was the "shut off if TPS sensor is above..." i had 80, but filled in 89. still doesnt work
when i turn on the A/C, the car definately bogs down as if the A/C were working, but no cold air will come out.
i guess the compressor is just not functioning properly??
Old Jan 5, 2007 | 02:42 PM
rraulston's Avatar
take a flashlight and look at the compressor clutch. Have someone turn it on and off, you should see the clutch engauge and dis-engauge. If you do, engauge it and let it run for a few minutes Find the "low side" comming out of the firewall and touch it. If its cold, then i would guess your thermostat knob may be broke and stuck on hot. If its not cold, get a set of gauges and read the pressures. If the compressor dont turn on, then thats a whole nuther can of worms....
CharliEvo8
Jan 5, 2025 10:14 AM
lghtngyello03
10
Jul 22, 2016 03:26 PM
Rough 01
21
Sep 2, 2010 04:04 PM
Brokenevo
Apr 18, 2010 07:32 PM
JT_EVO8
Nov 16, 2004 06:37 PM
