X help needed!
Old Apr 18, 2010 | 04:34 PM
Brokenevo's Avatar
X help needed!
OK so ya, installed the Mishimoto radiator, piping and the thermostat. Car of course is running alot cooler and now I am getting code 0128. Also I found out my A/C is not working, well not blowing out cold air. No A/C lines were removed or anything, so its not that. if the engine is running colder then normal the code usually pops, but the no A/C? if its running cooler would the A/C not work? ug, anyone?
Old Apr 18, 2010 | 04:44 PM
hotdog's Avatar
Does the compressor engage when you hit the happy AC button?
Old Apr 18, 2010 | 04:48 PM
Brokenevo's Avatar
I dont know how to check that.
Old Apr 18, 2010 | 07:06 PM
babyboy985's Avatar
look at the middle of the ac pulley with the ac button OFF....the middle of the pulley should not be turning ...now push the ac button ON and look at the middle part of the ac pulley...it should be turning...if its not turning then ur ac compressor is not kicking ON = no cold air....hope that clear things up
Old Apr 18, 2010 | 07:21 PM
Brokenevo's Avatar
cool thanks bro. I will go check that now actually. Im jet engine smart, but never got trained on car engines lol. I can do most swaps, I just need to take some classes and learn some more car stuff. Again thanks!
Old Apr 18, 2010 | 07:32 PM
Brokenevo's Avatar
ok from what I was viewing, the top pulley was always turning ( by looking at the nut) With fan on or off, a/c or heat the bottom 2 pulleys were not turning at all. Again I was looking at the nut to see if they were spinning. I also hate to say the bottom pulley is warped, what pulley is this for and what the heck would make it warped?
usnevo8
Aug 24, 2019 03:05 PM
lghtngyello03
10
Jul 22, 2016 03:26 PM
kr_3c
Jan 8, 2016 09:33 PM
meckert
Aug 25, 2011 06:20 PM
bspsrt-4
Lancer Troubleshooting
May 26, 2007 05:05 AM
