AEM EMS Get tuning help for your AEM EMS system.
cold weather starting with an AEM EMS
Old May 15, 2007 | 06:33 PM
Belly626's Avatar
i'm currently looking at picking up an evo VIII and looking at using an AEM management system, has anyone tuned this EMS for real cold starting? I have read up on tuning the system for "standard" cold starting on an evo but i am referring to Boston winter cold starting, i.e. 20 deg F cold starting.
I may be dreaming but my goal is an evo at around 400whp for time attack type racing that can still be driven in the winter in this part of the country, of course i will tune the engine down to something much more drivable in the winter but i think a true stand alone is required to reach my summer hp goals.
anyone tried it?
on a side note, can anyone recommend a good tuner in the Boston area?
thanks in advance.
Old May 19, 2007 | 09:20 AM
alpha's Avatar
I'm in Florida so luckily it doesnt get that cold I tuned a Supra a while back in Florida. He went back to MI and had no problems that I know of. Just take time with the Engine Start, Advanced Engine Start and Air Temp Fuel Corr
Old May 19, 2007 | 09:52 PM
Aby@MIL.SPEC's Avatar
my cars starts & drives fine after staart-up in 20f weather. i used to live in the high desert where 20f is common during the right time of the year.
the aem is an awesome device.
Old May 28, 2007 | 08:31 PM
kjewer1's Avatar
I'm also in MA, and this was my only car for the last two years until a few weeks ago. No problem starting down to zero degrees, aside from the fact that batteries don't like that ****. I've found that the best advice is to not have to many things arsing about with your fueling, you don't have to use every friggin table available. Assuming you have good warm startup settings, it should only take 2 or 3 cold starts to properly set up the warmup enrichment and ISC base tables. One of the most common mistakes IMO, which applies to me too, is trying to set up the ISC for all rpms with the motor warm. Set up your cold idle rpms with a cold motor.
The AEM has the functionality to start perfectly fine in very cold weather, you just have to put the time in to learn it.
ezzey
AEM EMS
11
Jan 20, 2016 08:46 PM
ezzey
Jun 20, 2015 09:14 PM
cerevo
AEM EMS
Nov 4, 2014 08:50 AM
Chris D.
Lancer Troubleshooting
Nov 4, 2011 05:36 PM
cacrawfo
AEM EMS
Feb 8, 2004 08:13 PM
