AEM EMS Get tuning help for your AEM EMS system.
JDM 3bar MAP sensor & AEM?
Old Oct 2, 2007 | 12:44 AM
XBS's Avatar
XBS
Can I use the JDM 3bar map sensor with the AEM? Any negative results by doing this?
Also can I use the stock MAF for IAT? or will it work better to use the AEM IAT Sensor? If so which is the most optimal location for the IAT Sensor?
Thanks for the help in advance.
-George
Old Oct 6, 2007 | 11:24 AM
awdboosted's Avatar
You can but I wouldn't, In that case you should just use the stock MAF. The whole reason in converting over to speed density is to get rid the MAF. I would invest in a AEM 5-bar and use the AEM IAT sensor. You can place the sensor anywhere after the FMIC.
Old Nov 9, 2007 | 05:19 PM
ty423's Avatar
Whats the reason for using a different map sensor other then stock? sorry a noob at this...just curious.
Old Nov 9, 2007 | 05:24 PM
ty423's Avatar
nevermind i found it in a few posts down...i guess it helps get rid of the MAF sensor as long as I get the IAT along with it....cool...already solved.
Old Oct 17, 2009 | 07:25 AM
mguyott3's Avatar
jdm 3 bar or aem either or
mines5
Oct 16, 2016 04:46 AM
EvilEvolution8
May 11, 2016 04:50 AM
EVO(boss)
May 5, 2016 10:37 AM
feldguy
Jan 17, 2006 09:34 PM
silverEVO8
18
Nov 17, 2004 09:01 PM
