AEM EMS Get tuning help for your AEM EMS system.
Pump Not Priming
Old Oct 11, 2007 | 07:25 PM
Mike.p's Avatar
Unhappy Pump Not Priming
the problem i am having is my fuel pump isnt priming....it stoped priming before i tryed a new base map..i figured it might of been my old map that caused it to stop..so then after the new base map it didnt fix it. so i straight wired the pump and it works.....so then i used a volt meter and checked the plug that goes into the pump and there is no power getting to it...i checked all the known fusses that would control the pump. is there a "special" fuse that i might need to check...or would it be the aem causing it????i have searched through 35 pages of "fuel pump not priming"...any body have any ideas????? please help im getting so frustrated......
Old Oct 12, 2007 | 12:48 PM
Spaceball 1's Avatar
fuel pump prime is not required, the stock ecu doesn't do it.
it should be a setting in the cal post it or send it bbyevo@hotmail.com
Old Oct 12, 2007 | 04:30 PM
Mike.p's Avatar
ill send it to you...thanks man
Old Oct 12, 2007 | 04:31 PM
Mike.p's Avatar
also if i switch between maps it still doesnt prime...it doesnt matter what map im using....
Old Oct 12, 2007 | 04:47 PM
gudmundur's Avatar
I have seen this once.
I was on my friends car.
His fuel pump primed sometimes and sometimes it didnt.
It was solved by uploading the 1.19 firmware again.
Old Oct 12, 2007 | 05:08 PM
Mike.p's Avatar
i just strait wired the pump while it was in the car and it started fine...soooo its either the ems program or a fuse/relay( i checked all that i know.....does any one know were to find the wiring scimatic of the fuel pump
Mike.p's Avatar
im about to try and upload that software agian
Old Oct 12, 2007 | 10:59 PM
Mike.p's Avatar
alright i pulled the pins for the ecu and pin number 22 has voltage coming from it....here is the diagram i went by..... http://www.roadraceengineering.com/e...-ecuwiring.htm
let em know what yall think......
Old Oct 14, 2007 | 08:20 PM
Mike.p's Avatar
new thread started found diff prob........thanks all
RenosEVO
Dec 9, 2013 11:56 PM
okevolutionVIII
15
Jun 25, 2012 07:45 AM
5LEEPERISAH23I
Dec 29, 2010 05:20 AM
mt057
Jan 30, 2010 11:14 PM
Mike.p
AEM EMS
Oct 31, 2007 06:49 PM
