AEM EMS First time install
Some one know where can I get a base map to start with? I have an Aem ecu for my evo 8, but the bad thing is than I move back to my country and here no buddy works with the AEM ecu's, so I don't want to mess up my engine.
My car mods are:
MECHANICAL
2.0 Liter I4 Turbo INJEN Intake and charge pipe
FQ400 Mitsubishi Titanium Wheel Upgrade Turbo
Buschur Full Race Intercooler
Buschur Turbo Out Pipe
Greedy 3” EVO exhaust
Cat Delete resonator
HKS 272 Cams
HKS Twin Power Ignition Amplifier
HKS Idle Stabilizer
Ralliart Plug Wires
Works Throttle Body
WR Engine Torque Stiffner
XS Tube Header
GFB Blowoff Valve
HBC Manual Boost Controller
APEXI Turbo Timer
Walpro 255 Fuel Pump
Dynoflash Reflash ECU
Optima Red Battery
ProSport Oil Pressure, fuel pressure, EGT, Boost, and narrowband Air/Fuel Gauges
TO BE INSTALL (not in the car jet)
BC Valve springs
Delfi 880cc injectors
Adjustable cam gears
Aquamist Methanol injection kit
AEM ECU
TRANSMISSION
Sheppard Racing Rebuilt Trans
Exeedy Twin Disc Clutch
SS Clutch line
B&M Short throw shifter
Brass Shifter Inserts
SUSPENSION
Cusco Front & Rear Shock Tower Braces
Cusco Lower front brace
Tanabe GS210 Lowering Springs
BRAKES
Hawk Pads
Slotted/Cross Drilled Rotors
SS Brake Lines
Motul Fluid
WHEELS
5 ZIGEN FN01RC Polished Rims
Falken FK452 235/40-18 Tires
My car mods are:
MECHANICAL
HKS 272 Cams
HKS Idle Stabilizer
Ralliart Plug Wires
Works Throttle Body
XS Tube Header
GFB Blowoff Valve
APEXI Turbo Timer
Optima Red Battery
BC Valve springs
AEM ECU
TRANSMISSION
SS Clutch line
SUSPENSION
BRAKES
Hawk Pads
SS Brake Lines
Motul Fluid
WHEELS
Base maps come with the aem software.
If you need someone to tune it and no one does where you live then you could talk to someone about flying out to tune it. It would be costly but thats what you'd have to do.
You might talk to Evil__eagle.
Well, I have a friend than works with haltech computer, so if I can get a base map or a tuning map according with what I have on the car, he can adjust a little and will be safer and easier.
Do you know how much will cost to get someone flying to PERU?
metaphysical
19
Apr 12, 2005 05:36 PM
