AEM EMS Get tuning help for your AEM EMS system.
strange ignition sequence problem
Old Apr 29, 2010 | 10:24 AM
fbrs's Avatar
hi all
i've installed a 1313 box today but a very strange thing happens...
everything in order and wired (map,ait) and the car doesn't fire at all....
after 2 hours of searching we've found that the only way to make the car start and work as it should, is to change the coil packs sequence in the engine head...
i mean we plug the left connector to the 1-4 and the right to the 2-3.... and the car fires up instantly!
what is the problem here???
should i swap the coil wires in the ecu harness? how the car is working with the evo8 stock ecu as it should and with the aem unit is not?
thanks...
Old Apr 29, 2010 | 11:25 AM
project_skyline's Avatar
What car is it?
Old Apr 29, 2010 | 06:19 PM
fbrs's Avatar
evo 6
Old Apr 30, 2010 | 02:02 AM
You can't just throw an EVO 8 AEM on an EVO 6 and expect it to work the same. I'm not familiar with the evo 6 but I know its different enough to not just be PnP. If it was an EVO 7 you'd be ok probably.
Things are probably wired differently on the harness, that's probably your issue.
Old Apr 30, 2010 | 02:31 PM
fbrs's Avatar
no man its not the harness, pinouts of 6-7-8 as almost identical and that's why we can run evo7/8 ecus with 90550001 on 6's
anyway
the problem found and its in the cam sensor compatibility with the 1313 box.
NigHtcRawl3R
Jan 20, 2013 11:14 AM
neonglh
Jun 6, 2011 03:19 PM
Mitsu.kid.02
Lancer Engine Management / Tuning Forums
15
Dec 14, 2010 03:49 AM
williillii
Feb 7, 2010 12:09 PM
Raheelq
Dec 12, 2009 11:59 AM
