AEM EMS Get tuning help for your AEM EMS system.
*How to setup idle for AEM ECU*
Old Apr 9, 2013, 08:26 PM
  #61
Paul Walkin's Avatar
Cold start issues with a properly set idle are usually fuel related. What kind of AFR's are you seeing at 800 rpms before it dies?
Old Apr 11, 2013, 06:53 AM
  #62
Kayosfrawg's Avatar
It was really lean. There was a hole in my fuel map right where it wanted to idle, I fixed it and made it more stable, as in it no longer just dies, but it's still trying to idle at 800 when it should be at ~1300. The AFR's I'm getting when driving cold are still leaner than when I'm warm. Is this by chance something to do with warmup enrichment? I'm just guessing tho...I can log it later when I cold start it after work today. Anything in particular I should be logging beyond AFR, Engine Speed, etc?
Old Apr 12, 2013, 05:34 AM
  #63
Kayosfrawg's Avatar
Okay my laptop decided to take a dump all over itself yesterday :/ No logs til I fix it. Hopefully I'll be finished by this afternoon.
Old Nov 26, 2013, 01:03 PM
  #64
Pirana's Avatar
thanks for the post, I am in the process of tuning the car and that really helped me a lot!! Car is idling pretty good. I am stock now on the O2 FB, you say to set the table to 14.7 on the idle cells. Im I in the correct table? If so, they look pretty off! Any suggestions, thanks!!
Old Nov 27, 2013, 10:09 AM
  #65
eeweeks's Avatar
It looks like your load breakpoints are off. I like to use psi instead of kpa. It's more relatible for me.
Old Nov 27, 2013, 04:22 PM
  #66
Pirana's Avatar
Is an AEM v1 I don't know how to change it.
Old Sep 16, 2014, 02:59 PM
  #67
EvoDan2004's Avatar
i tried to do as the O/P said. but i am not sure if i did it correctly. how does this graph look compared to anyone elses? does it appear i did it correctly?
Old Dec 31, 2014, 08:02 AM
  #68
doghouse's Avatar
Nice
Old May 14, 2017, 03:40 AM
  #69
scoobydo's Avatar
Anyone still watching this thread? I have idle issues, my car apparently has had 1000's spent but my idle learned value is always in the red 14% plus car does idle but doesnt do what it is supposed to do. It is on a series 2 ECU running latest firmware and latest tuner software. Could set up teamview or something for someone to have a look :-)
Thanks
Old May 18, 2017, 01:55 PM
  #70
cerevo's Avatar
There is a Youtube series specifically for the AEM V2 by "Jonathan Fasking" I believe, where he goes through the full setup and tuning of the device. You may try that.
I know that if your fueling isn't very good, you'll have trouble everywhere else.
Old Jun 30, 2017, 07:24 AM
  #71
Cogito's Avatar
If anyone is going to be able to help, a detailed info on current setup would be needed.
Old Jul 17, 2017, 02:21 PM
  #72
J. Fast's Avatar
Jonathan Fasking U-Tube training series on AEM EMS is an awesome resource. 16 Videos in total. I am an EFI University Certified Tuner and have attended AEM advanced course training and AEM V2 specific training and his videos are spot on. Sub'd for future ref.
Old Mar 1, 2019, 12:57 PM
  #73
BillAce's Avatar
Old thread but this info was very useful so I figured I would ask here. My Evo was stored for many years and ran great on an AEM v1. Took the car out and went over nut & bolt and finally fired it back up. It is a little tough to start when cold and the idle would surge from 900-2300 which led me to this thread. it otherwise is running well on the previous tune, After adjusting these settings I got the car to idle smoothly at 1200 when up to temp but when I blip the throttle it hangs and sits around 2000 when off throttle pretty much indefinitely. I'm thinking there is an enrichment somewhere that isn't tapering with temp or RPM somewhere?
It is also seems to catch faster when starting, but stumbles at 800 for a few seconds then surges to 2000 before settling to 1200 after ~10s. The injector all checkbox is on and the crank timing is 10 deg. I figure this was affected by the idle settings.
I know this place is pretty dead but hopefully someone with more experience than me can chime in.
Thanks,
Bill
Old Mar 2, 2019, 08:35 PM
  #74
MasterNater's Avatar
Thanks,
Bill
Hey Bill. With your laptop connected and AEMPro running, go to your main Idle page. Make sure the Parameters window is active, and then press F6 to start logging. Blip the throttle to get the idle to surge and hang. Then, press F6 to stop logging. Email me the log and your calibration files to EvolutionNate@gmail.com. I'll take a look and see if I see anything out of the ordinary.
Nathan
BillAce (Mar 4, 2019)
Fast_Freddie
Oct 30, 2023 01:56 AM
mrfred
Aug 1, 2022 06:05 AM
MitsuAK
Jun 22, 2017 10:44 AM
TouringBubble
May 2, 2017 11:28 PM
TomasThijs
Apr 2, 2016 02:55 PM
Quick Reply: *How to setup idle for AEM ECU*
