AEM EMS Get tuning help for your AEM EMS system.
Setting up NLTS -- How
Old May 27, 2011 | 05:34 PM
TheBoz's Avatar
So I swapped the pins on the ecu from #43 Clutch Switch to #37 Switch #5, I am not getting anything. My ecu for Switch #5 always stays on.
Anyone that setup there NLTS with the top cluch switch how did you set it all up.
Thanks
Old May 27, 2011 | 06:09 PM
TheBoz's Avatar
Dont worry about it I got. For some reason it did not like me using switch #5. I moved it to switch #6 pin #44 and everything is all good.
Old May 27, 2011 | 06:11 PM
TheBoz's Avatar
So for anyone that wants to know how this is done, you do not have to mess with anything in the pedal box, you simply remove pin #43 from the ECU, and move it into position #44. You will need to setup your ems with switch #6 gnd=On.
Old May 27, 2011 | 06:15 PM
Gordian79's Avatar
Where in software do I adjust nlts settings?
Old May 29, 2011 | 08:57 AM
TheBoz's Avatar
Here is a thread that goes into detail.
https://www.evolutionm.net/forums/ae...setup-nls.html
Old May 29, 2011 | 09:25 AM
mt057's Avatar
Old May 31, 2011 | 07:42 AM
BillSpec's Avatar
Glad you got it worked out Boz
Now post a vid of it in action.
Old May 31, 2011 | 10:40 AM
TheBoz's Avatar
Race track is this weekend. Will have video up after.
Old Jun 2, 2011 | 01:47 PM
Aby@MIL.SPEC's Avatar
what rpm is your 2step set to? are you going to fontucky? i found i was able to get a better launch @ the track, setting the 2step slightly below my peak tq rpm.....sounds goofy, but it worked for me @ fontucky. anything greater than 5k = massive wheel spin, i turned it down to ~4k iirc, the car left hard & was easier to control. i was making ~410wtq @ 4200rpm on 91oct.
just know that, the nlts rev limiter vs throttle position over-rides the max rev rev limiter.
in fact, any switch activated rev limiter that is triggered, has the ability to go above & beyond the max rev limit.
if anyone say's otherwise, they are wrong, as i spoke to the person who wrote the code to confirm this....
in fact, set your max rev limiter to 3k & put your 2 step anything higher to confirm this.
Old Jun 2, 2011 | 04:59 PM
TheBoz's Avatar
Hell yes fontucky is awesome. It is also within my tow distance .
Ya I already saw the max rpm thing. I was like WTF. I just figured that the Revlimiter was your max and everything else needed to be less, but with the Anti Lag that is not the case.
2step is at 6k and 12psi, and the car just breaks the tires loose in 1st gear. I will drop it down and see if I can get it to squeeze out a faster 60'.
GravityKnight
AEM EMS
Apr 2, 2015 10:30 AM
Tmosser
Aug 8, 2012 12:13 AM
evo8john
Jun 5, 2012 10:01 PM
stunt2
Aug 18, 2011 08:53 AM
nocabiwiksmx
Apr 6, 2009 01:31 AM
