AEM EMS Get tuning help for your AEM EMS system.
Evo wont start with AEM EMS and has dead cyl number 2
Old Aug 2, 2011 | 10:43 AM
JDM EVO PANAMA's Avatar
When the car gets the OEM ECU put back on it fires right back up however it has a dead cyl number 2.
Engine was taken apart everything checked out fine we put a new head gasket on it.
Took the head to a machine shop and everything was fine.
It wont even start with AEM EMS.
What could be wrong?
We checked the resister, injector signal, spark.......
Old Aug 2, 2011 | 12:12 PM
browningderek's Avatar
If it runs with the stock ecu and not with the aem my guess is your using the wrong basemap and/or the tables are way off. Could be a bad ecu buy i doubt it.
Old Aug 2, 2011 | 01:24 PM
Car ran fine before and its tuned.
It runs with the stock ECU but like crap with a dead cylinder.
Old Aug 2, 2011 | 01:41 PM
TheBoz's Avatar
you might want to be more specific about your setup. List out your mods and tell us what base cal you are using.
Old Aug 2, 2011 | 02:02 PM
PTE 62 kit
AEM EMS w/ 3.5 Map sensor
PTE 1200cc Injectors
Aeromotive Fuel pressure regulator
Aeromotive Fuel Rail
Aeromotive Fuel valve
Walbro 255 fuel pump
Base cal what do you mean ?
Old Aug 2, 2011 | 05:52 PM
1313map should work. do you have an aem iat sensor?
Old Aug 3, 2011 | 04:23 PM
yes I do I dont understand what this problem is
Old Aug 3, 2011 | 05:21 PM
project_skyline's Avatar
So something happened with the engine and now it doesn't start on AEM?
Could be AEM, seen that before.
Old Aug 4, 2011 | 09:27 AM
itzwolf's Avatar
Am I the only one that reads it starts on stock ECU but cylinder #2 is not firing? It's not AEM related but rather something with the car itself and needs fixed before moving forward with AEM.
You said its was tuned was that on AEM or stock ECU and the problem was found when switching?
Verify the following for cylinder #2:
1) You are getting a strong spark (I know you said you do got spark but is it strong enough?)
2) You are getting fuel (is the injector actually spraying fuel/top of piston wet?)
3) You infact have good compression
And as far as the base map I have found the v1 box calibration isnt even close for much of a sputter (if that) and needs a full tune to actually run the car properly. Once you solve your cylinder #2 problem you'll need someone to assist with tuning to get the car running on its own. Of course this only applies if it wasn't already tuned on AEM but this was clearly stated what it was tuned on.
Old Aug 4, 2011 | 09:23 PM
Car was tuned on AEM EMS.
It wont even start with the AEM EMS.
It starts with the stock ECU.
The car had 150 compression to all 4 cyl.
However the motor was taken apart eitherway we changed the head gasket and took the head to a machine shop. The car was tuned already.
We tried other PTE 1200cc injectors and I guess cyl #2 is getting spark but it might not be strong enough. I will ask my mechanic how can he see or make sure its getting enough spark.
Old Aug 6, 2011 | 12:17 AM
Sounds like bad AEM ecu and a ignition or fuel problem with cylinder 2. Check your harness and verify fuel and spark.
If your on stock ignition make sure the wires are in all the way on your coil packs.
Old Aug 6, 2011 | 09:31 AM
BillSpec's Avatar
missing on cyl 2.... not starting with aem.... Check stat sync in aem... and cam/crank signals
Old Aug 6, 2011 | 11:28 AM
TheBoz's Avatar
itzwolf is on point. If the issue is there with both the Stock ECU and AEM EMS, it sounds like an issue with the car, or how things are setup in the car. Sounds like it is time to dig through the wires and start checking each system one by one.
Old Aug 10, 2011 | 11:45 PM
BillSpec's Avatar
At least check for stat synch and all.
Then try some known good coils from a working evo.
Old Aug 11, 2011 | 12:46 AM
signcutter's Avatar
Aem will not work if car is not right. The Aem is already very fincky. There is no way the Aem will fire up with dead cyl wiring issues and maybe low battery low alt voltage. All that needs to be checked. Get your dead cyl issue resolved with oe ecu. Then start with cam crank sensor ie stat sync with your aem. If you can try another Aem after those first things are worked out then you could detrmine if yours is bad or you still have probs.
Tw3NTy0n3
May 21, 2016 11:24 PM
Tarvi Trees
Nov 16, 2015 03:11 AM
300zxhks
13
Nov 4, 2014 04:37 PM
Throttle
20
Jan 21, 2012 07:41 AM
Raheelq
AEM EMS
11
Jan 15, 2010 09:23 AM
