AEM EMS Get tuning help for your AEM EMS system.
AEM 1313 bad start
Old Aug 14, 2011 | 11:34 PM
vladevoIV's Avatar
AEM 1313 bad start
Hello, friends!
I have a trubl with cold start! ia have evo 4. 1000 CC-RC,272 cams BC,walbro!when it's 20 degrees +,it's all right,but when less than 20 degrees, ia have problem with start! no flash,and after 2-3 min i have a the flow of gasoline from the exhaust manifold!what to do?
Old Aug 15, 2011 | 02:57 PM
BillSpec's Avatar
Raw fuel dripping from the manifold?
Old Aug 15, 2011 | 09:31 PM
vladevoIV's Avatar
yes. fuel dripping from exhaust manifold and on the floor!
but yesterday i had a problem with ign, evo stoped and didn't star,than was star some times worked and tachometer needle was jumping up to 5,000 rpm,Then again stalled and pops into the muffler.
Old Sep 5, 2011 | 05:29 PM
vladevoIV's Avatar
hello!i changed crank position sensor,and problem stay!fills the first cylinder,other cylinders, dry!
what happend?help me please
Old Sep 11, 2011 | 05:56 PM
M4Lki3r's Avatar
Veteran: Marine Corps
Have similar issues, but not quite as bad. It is a known issue that the AEM EMS does not like cold weather, cold starts. I think I have flooded the engine once, but pulled the plugs, let it sit for 5 min, put the plugs back in and it started up in a few cranks.
Check the AEM EMS forum for tuning the 1313 specifically for cold starts.
Old Sep 12, 2011 | 11:26 PM
vladevoIV's Avatar
oh,and what can i do?give me link pls and +18 it's no cold))))
Old Sep 13, 2011 | 12:59 AM
SLO-EVO's Avatar
There is a sticky for the AEM cold start. I would start there.
Old Sep 14, 2011 | 03:21 PM
vladevoIV's Avatar
What did you meanth?More details?
Old Sep 15, 2011 | 02:18 PM
BillSpec's Avatar
Vlad, send me your map, I can check it out If u like to see if its a software issue... billspectuning@gmail.com
Old Sep 15, 2011 | 02:30 PM
BillSpec's Avatar
https://www.evolutionm.net/forums/ae...-evo-viii.html
Evo viii start thread
Old Sep 18, 2011 | 03:32 PM
vladevoIV's Avatar
Hello
One more question, car will not start and when I heat the dryer(warm)
ECU and the car starts/
what happend?
Old Sep 18, 2011 | 04:18 PM
vladevoIV's Avatar
i sent you my map.thanks
CH@Dbee
Apr 21, 2011 10:23 AM
LV///R
Midwest Region
Aug 5, 2009 10:35 AM
brandonseydel
Midwest Region
Apr 13, 2009 02:07 PM
IA Performance
European Forum
Jul 25, 2008 12:29 PM
DaWorstPlaya
Midwest Region
17
May 5, 2006 10:31 AM
