AEM EMS Get tuning help for your AEM EMS system.
map not saving?
Old Oct 9, 2011 | 12:11 PM
n2oiroc's Avatar
map not saving?
im having an issue on my evo 8 series 1 where the map seems to be changing itself after the car sits a while. my original map was too lean at startup so i richened it up. after sitting it surges and runs lean, i reflash the new map and problem solved. am i doing something wrong here?
ecu>send new calibration>choose map>upload
Old Oct 9, 2011 | 01:14 PM
TheBoz's Avatar
did you compare the map that was causing the car to run lean to the good map? It sounds like something else is wrong. I have never heard of a map reverting to a different map. I am pretty sure that is not even possible.
Old Oct 9, 2011 | 06:25 PM
n2oiroc's Avatar
Thanks for the input, ill try that next time i start it.
Old Mar 17, 2013 | 04:36 PM
Evolution7GSR's Avatar
did you ever find a solution to this because I am having the same problem!!!!
Old Mar 18, 2013 | 03:38 PM
browningderek's Avatar
Update your firmware and see if that helps... its in one of the drop down menus
Old Mar 19, 2013 | 09:53 AM
Aby@MIL.SPEC's Avatar
call aem help desk, they are very helpful.
it will take you less time then posting on here & waiting for a reply.
for me, i dont know how the ecu can change maps, as it only has the ability to hold 1 map.... or at least that is my understanding.
GL
Old Apr 13, 2013 | 07:24 AM
shaz1980's Avatar
did u find out Y is it reverting back
babaz7
May 27, 2021 11:35 PM
Vigman
Jun 30, 2010 11:27 AM
EvolNinja
May 24, 2010 10:04 AM
gudmundur
AEM EMS
17
Aug 8, 2007 07:03 AM
EiEVO
Jun 13, 2006 10:17 AM
