AEM EMS Get tuning help for your AEM EMS system.
02 sensor doesnt log internal 1313u
Old Dec 9, 2012, 10:57 AM
20austin08's Avatar
Question 02 sensor doesnt log internal 1313u
Hello everyone, recently I installed a Aem 1313u ems with the internal wideband controller. Installed the ecu and the wideband and hooked them up with the cable that I had to make with the connectors they sold me. I have tried all the different selections in the 02 sensor wizard and changed the gain to what it says and none of them make the afr log on the aempro software. The volts and afrs stay pretty much the same 14.7 to like 14.9 on the software regardless of the actual afr. When I turn the key on from cold the sensor warms up like it is supposed to. I'm kind of stuck as to what the issue might/ could be at this point. I have checked the wiring it is all done to the correct spots via the diagram the tech sent me. Any ideas or suggestions? Thanks
Old Dec 12, 2012, 07:28 AM
20austin08's Avatar
Hump day bump
Old Dec 12, 2012, 11:36 AM
browningderek's Avatar
What you need to do is find the 5v wire at the sensor and jump it to the signal wire going to the ecu. You AFR should read 10.0..... if it does replace the sensor. If not you have wiring or ecu issues.
Old Dec 12, 2012, 01:18 PM
20austin08's Avatar
I have two brand new UEGO sensors i have been pluggin in and switchin so its shouldnt be the sensor. they both warm up like they are supposed to. So I guess it could be wiring or actually the ecu at this point. Does anyone have the wiring diagrams or colors that they are using on a 1313u model so ems side and the sensor side so that I can check mine against yours?
Old Dec 12, 2012, 05:47 PM
Contact Aem tech support. They can get you the wiring diagrams you need. I don't have an 1313u so I cant tell you what is what. Sorry .
Old Dec 13, 2012, 01:57 PM
99EclipseGSX's Avatar
This is to build a new "U" harness but the information still applies:
1x – 3-1201-12 (EMS-side connector
6x – 3-1000-S (pins, may wish to order spares)
1x – 35-2613 (sensor-side connector/pin kit)
Wire as follows, original wire colours retained for easy identification.
Sensor side, Wire-side view, looking into connector with connector lock facing up:
Black – Brown -- Orange
Green -- White -- Red
EMS side, wire-side view, looking into connector with connector lock tab facing up:
Red – Orange – Black – Green – Brown – White
(Bottom row empty)
herrrta
AEM EMS
Oct 26, 2016 03:16 PM
stokEd
51
Oct 14, 2015 06:44 PM
XTR Performance
Evo 'For Sale' Electronics / Lighting / Audio
322
Jun 5, 2013 08:19 AM
Andrew@AMS
Automotosports - Illinois
Sep 18, 2012 07:01 AM
XTR Performance
19
Aug 22, 2012 08:33 AM
Quick Reply: 02 sensor doesnt log internal 1313u
