AEM EMS Get tuning help for your AEM EMS system.
Map sensor question / issue
Old Jun 16, 2014 | 02:52 PM
domyz's Avatar
Hi, I installed a AEM 5 bar map sensor on a car and I can't change the map min volts to any number that has decimals.
If I enter "0" or "1" it works. But I cannot enter i.e. "0.5" volts. Is this normal ? Where and how to change the map min volt value?
Old Jun 17, 2014 | 05:21 PM
Aby@MIL.SPEC's Avatar
aempro/set-up/sensors/manifold pressure sensor/map sensor wizard
select your sensor from there & that will configure the proper sensor for you.
but if you need to change the voltages for what ever reason.....
aempro/set-up/sensors/manifold pressure sensor/options-Map sensor
mrfred
Feb 26, 2022 06:16 PM
Benja
Jul 3, 2019 12:42 PM
mrfred
Sep 17, 2017 06:11 AM
joat09
Sep 8, 2016 01:20 PM
Raceghost
Jun 21, 2016 12:40 PM
