AEM EMS Get tuning help for your AEM EMS system.
aem base map?
Old Mar 10, 2004 | 12:23 AM
mazdryk's Avatar
aem base map?
I just ordered my plug and play aem ems with the wide band uego. I was wondering if the base map it comes with is ok to run on my car for a while and also will it add any performance? I am new to tuning and was wondering how hard the auto map function is to use? I only have a 3 inch RNR turbo back exhaust. I will be purchasing the map sensor soon and getting an intake.
Old Mar 11, 2004 | 11:39 AM
Wadzii's Avatar
the base map will run your car fine... its pretty conservitive. but honestly i wouldnt bother putting the ems in till you get the map and ait sensor. no sence in having to set everything up twice.
Old Mar 11, 2004 | 06:09 PM
LANEVOLUTION8's Avatar
have a 3 bar map sensor for sale for aem p&p im installing a 5 bar map. does any one no what kinda numbers hp i should see.
2.75 hks dp 3in test pipe 3in hks carbon ti exhust. 5 bar map. aem p&p with hks evc pro. thanks running 104 oct.
Old Mar 11, 2004 | 08:44 PM
Wadzii's Avatar
id expect around 320-335hp
we made 303 hp with basicly the same setup minus the test pipe and on pump gas
Old Mar 12, 2004 | 07:36 AM
kcevo's Avatar
Why are you going with the 5bar map sensor? Do you plan on major upgrades shortly, similar to what George is doing at Boost Solutions?
Old Mar 20, 2004 | 04:06 PM
im going for some big mods soon. just got off the phone with hks and they said some time this year there coming out with the gt intercoller kit for the evo 8. thats gonna be my need mod along with fuel pump with injectors. i hope hks will make a fuel pump for the evo. does any one know of any real good companys that makes good injet... and fuel pump?
Old Mar 28, 2004 | 09:31 PM
Wadzii's Avatar
i always like to use the 5bar sensor. i setup all my maps using the boost comp method. if something happens to the boost control this method will provide fuel for any boost pressure up to the limit of the map sensor. in a customers turbo civic this has saved him a few times when he had vac lines blow off..... 42psi on a huge turbo (around 500hp at 16psi) and it held together just b/c of that.... afr was perfect all the way up.
Old Apr 14, 2004 | 11:12 AM
johnjonfenomeno's Avatar
I made 302 on just the AEM. The rest of the car fully stock on the DYNOJET. I had my car tuned by Mark French(TurboTrix) and Jason Siebels(AEM)
Old Apr 14, 2004 | 11:21 AM
evo542's Avatar
but the 5bar MAP sensor is not as accurate at low boost as the 3.5bar correct?
Old Apr 14, 2004 | 11:42 AM
Wadzii's Avatar
no, as long as you set it up properly there is no difference
Old Apr 15, 2004 | 01:22 AM
Blak94GSX's Avatar
On paper there is less resolution, since a smaller change in the sensor voltage results in the same pressure change, but realistically the AEM MAP sensors are very precise and whether you choose the 3.5 or 5 BAR sensor, it will be real close and real consistent.
The AEM sensors are actually more accurate than most boost gauges on the market.
DailyRally
Feb 25, 2017 05:00 PM
saxon
AEM EMS
Apr 21, 2016 06:53 PM
jameswwt
Sep 18, 2015 05:49 AM
omtorlak
AEM EMS
Oct 2, 2007 11:03 PM
evoblack9
AEM EMS
Oct 15, 2005 08:01 PM
