AEM EMS Get tuning help for your AEM EMS system.
Aem trigger disk
Old Aug 17, 2014 | 06:58 PM
seascooby's Avatar
Aem trigger disk
I have an evo8 with a v2 aem ems that im trying to setup a trogger disk 12 tooth disk on. Before you start saying go search. I already have and all the threads have never had any answer posted. I found the one from kigglys sight. But it is not working. Stat sync turns on just not firing up. I can see change on all the t1per t2per etc
Old Aug 21, 2014 | 06:23 AM
itzwolf's Avatar
Did you perform a timing sync which is absolutely required?
The only Series 2 car I've done with a trigger disc needed a lot of ignition sync adjustment before it fired because it was so far out.
Try the following as a starting point:
Ignition Sync "19.141"
Pickup Delay Comp "109.6"
Also don't forget to turn OFF the "EVO IX" option. This is the quick start feature Series 2 has for the stock 2 tooth crank/cam setup but with the trigger disc its no longer going to work.
Give that shot as a starting point report back and I'll help get you going.
evo9ben
AEM EMS
Sep 8, 2018 08:18 AM
real fast
16
Nov 21, 2016 09:49 AM
twinturbogreg
May 7, 2014 08:47 AM
TonyPajamaz
Nov 25, 2013 09:33 PM
mystick
Lancer Troubleshooting
Apr 21, 2008 12:59 PM
