AEM EMS Get tuning help for your AEM EMS system.
Fuel pump keeps running when engine is off
Old Jan 24, 2015 | 09:12 PM
PHILLY EVO's Avatar
Hey guys I'm running a 2003 Evo 8 in a 1987 Porsche 911. I am using AEM EMS I had to switch fuel pumps from the stock Porsche turbo to the Bosch 044 which has 75.3 psi compare to the wallbro 255 which is 45.psi
So I turn the key on engine off the pump will keep pumping. I thought it stops after it reaches its pressure.
Old Jan 25, 2015 | 12:01 AM
TheBoz's Avatar
There is a fuel pump prime timer that you can set. If you set it to the max the fuel pump will not turn off. You should lower it to like 1-2 seconds something like that. I don't remember the exact value.
Old Jan 25, 2015 | 01:44 AM
PHILLY EVO's Avatar
OK cool thanks
Retty4113
Jul 27, 2018 11:52 PM
MisUnderStood
Dec 16, 2015 08:53 AM
Carloverx
14
Dec 22, 2011 01:00 PM
bud_thoj
Mar 20, 2007 06:41 PM
