AEM EMS Get tuning help for your AEM EMS system.
Need help
Old May 1, 2017 | 03:26 AM
naseem razzaq's Avatar
Need help
Recently finished with installing aem 1313u in Evo 5. When I try to start the car as per given wiring by aem it backfires and never starts. While if I reverse the ignition coil wires on the ecu it starts like normal and even revs ok.im just concerned cuz ignition coil 1 is running from ignition coil 2 signal and ignition coil 2 is running from ignition coil 1 signal but engine starts normal and revs normal ive checked setting in aem pro as well and still can't figure out and if I put a stock ecu on this wiring it doesn't start and I have to wire them like they r supposed to and it starts on stock ecu
Old May 3, 2017 | 02:27 PM
MasterNater's Avatar
Hmmm...that's a strange one. After looking at the ECU pinout and instructions for the AEM 1313, pin 10 is for coil #1 and pin 23 is for coil #2. Those pin assignments are identical between the Evo V and Evo VIII, and since the AEM EMS is designed to be plug and play for the VIII, there shouldn't be any issues there. As you said, everything works when using the stock ECU.
Have you sync'd the ignition timing on the AEM? That's the only thing I can think of.
Old Jun 30, 2017 | 07:26 AM
Cogito's Avatar
Increase/decrease trigger offset by 180 degrees, for wasted spark ignition.
Old Sep 11, 2017 | 08:26 AM
cchapa089's Avatar
i have a 2003 evo 8 and im looking for a aem series 1 and cant seem to find one for a decent price, probably a long shot but if anyone has one for sale or knows where i can find one without paying a arm and leg please let me know.
Old Sep 14, 2017 | 06:30 PM
shutterboy10's Avatar
5 Year Member
i got one, i could give you good price
Old Sep 16, 2017 | 10:17 AM
cchapa089's Avatar
how much are you looking for to get rid of it?
Earthen
23
Jul 22, 2010 06:43 AM
drc
Jul 19, 2005 08:33 PM
Kwman
21
Jul 14, 2005 07:34 AM
army685
Apr 26, 2005 05:43 AM
TeamNeXusOz
West Region
Jun 9, 2004 08:56 AM
