AEM EMS Get tuning help for your AEM EMS system.
Weird EMS things
Old Sep 10, 2004 | 11:05 AM
Hooptie157's Avatar
Weird EMS things
I have some funky stuff going on after the EMS was installed:
1st off if I turn the key the assesory setting I hear a crackling sound from under the hood, what the hell is that?? Also every time, and I mean EVERY TIME, I turn off my car my fan turns on for 2 seconds. I don't know why but it does.
Does anyone else have these problems?
Old Sep 10, 2004 | 11:54 AM
IEXCELR8's Avatar
Hey my fan runs for about the same time.I think it is normal.I do not here cracking at all.
Old Sep 10, 2004 | 02:35 PM
mdzuricky77's Avatar
Are you hearing your boost solenoid? Mine is pretty loud when the ignition key is on.
Old Sep 10, 2004 | 02:37 PM
2k4EvoVIII's Avatar
Ya the crackling is probably your boost solenoid if you upgraded to a GM solenoid. The Fan is normal. You can change it to stay on as long as you want or not even turn on at all. Its just to help cool things when you shut down the car.
Chris
Old Sep 10, 2004 | 05:12 PM
Blak94GSX's Avatar
The fan relay is inverted, so when the relay is off the fan is on and vice versa. When you turn the key off the EMS cuts power to that relay and the fan kicks on, until the Main Relay powers off which is a settable time parameter. It sounds like yours is set to about 2 seconds... On the plus side it lets things cool down more, so it is a feature...
The clicking/grinding noise is either your boost control solenoid or the idle speed controller stepper motor. The EMS will park the ISC at key off, and depending on how you have the boost controller set, might make the relay click. Technically the boost control solenoid is clicking all of the time, but you don't notice it with the engine on.
durangorider
AEM EMS
12
Apr 27, 2010 09:29 AM
BizarroEvo
Mar 23, 2010 04:54 PM
gudmundur
11
Jul 19, 2008 01:21 PM
RSGuy
10
Sep 26, 2007 08:57 AM
Lancematic
AEM EMS
Nov 11, 2006 04:47 PM
